Attach a PC VGA port to a switchbox. This 6-foot VGA Video Monitor Cable features two HDDB15 (male) connectors, providing a high quality VGA connection.
The cable supports a maximum video resolution of up to 800x600. For applications that require higher resolutions, see 6ft Coax VGA Cable (MXT101MMHQ).
StarTech.com 6 ft. (1.8 m) VGA to VGA Cable - HD15 VGA Cable - 800x600 Resolution - Male/Male - VGA Monitor Cable (MXT101MM) - VGA cable - 1.8 m
VGA cable
Shielded
Length
1.8 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
Grey
P/N: CDP2VGA, CDP2VGAUCPW, MDP2VGAAMM2M, MDP2VGAAMM3M, SV231DVGAU2A, SV431DVGAU2A, USB32VGAEH3
VGA cable
Shielded
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
1.8 m
Grey
Connector
3ZK3 StarTech.com Slimline Adapter HDDB15 F/F In Stock £5.07
3ZK3 StarTech.com USB to VGA Multi Monitor External Video Adapter In Stock £49.71
3ZK3 StarTech.com Right Angle VGA to VGA Cable Adapter Type 2 - M/F In Stock £7.03
3ZK3 StarTech.com 1 ft VGA to 2x VGA Video Splitter Cable – M/F In Stock £12.97
3ZK3 StarTech.com USB to VGA External Video Card Multi Monitor Adapter – 1920x1200 In Stock £46.67
3ZK3 StarTech.com USB 3.0 to VGA External Video Card Multi Monitor Adapter for Mac and PC In Stock £67.18
3ZK3 StarTech.com Slim USB 3.0 to VGA External Video Card Multi Monitor Adapter – 1920x1200 / 1080p In Stock £53.79
3ZK3 StarTech.com USB 3.0 VGA Video Adapter In Stock £45.86
