Attach a PC VGA port to a switchbox. This 6-foot VGA Video Monitor Cable features two HDDB15 (male) connectors, providing a high quality VGA connection.
The cable supports a maximum video resolution of up to 800x600. For applications that require higher resolutions, see 6ft Coax VGA Cable (MXT101MMHQ).
- StarTech.com 6 ft. (1.8 m) VGA to VGA Cable - HD15 VGA Cable - 800x600 Resolution - Male/Male - VGA Monitor Cable (MXT101MM) - VGA cable - 1.8 m
- VGA cable
- Technology
- Shielded
- Length
- 1.8 m
- Connector
- HD-15 (VGA) - male
- Connector (Second End)
- Grey
- Limited lifetime warranty
- Designed For
- P/N: CDP2VGA, CDP2VGAUCPW, MDP2VGAAMM2M, MDP2VGAAMM3M, SV231DVGAU2A, SV431DVGAU2A, USB32VGAEH3
- VGA cable
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Length
- 1.8 m
- Grey
- Connector
- 15 pin HD D-Sub (HD-15) - male
- Designed For
StarTech.com Slimline Adapter HDDB15 F/F | In Stock | £5.03 |
StarTech.com USB to VGA Multi Monitor External Video Adapter | In Stock | £49.71 |
StarTech.com Right Angle VGA to VGA Cable Adapter Type 2 - M/F | In Stock | £7.03 |
StarTech.com 1 ft VGA to 2x VGA Video Splitter Cable – M/F | In Stock | £12.97 |
StarTech.com USB to VGA External Video Card Multi Monitor Adapter – 1920x1200 | In Stock | £46.67 |
StarTech.com USB 3.0 to VGA External Video Card Multi Monitor Adapter for Mac and PC | In Stock | £67.18 |
StarTech.com Slim USB 3.0 to VGA External Video Card Multi Monitor Adapter – 1920x1200 / 1080p | In Stock | £53.79 |
StarTech.com USB 3.0 VGA Video Adapter | In Stock | £45.86 |
