Attach a PC VGA port to a switchbox. This 6-foot VGA Video Monitor Cable features two HDDB15 (male) connectors, providing a high quality VGA connection.
The cable supports a maximum video resolution of up to 800x600. For applications that require higher resolutions, see 6ft Coax VGA Cable (MXT101MMHQ).
StarTech.com 6 ft. (1.8 m) VGA to VGA Cable - HD15 VGA Cable - 800x600 Resolution - Male/Male - VGA Monitor Cable (MXT101MM) - VGA cable - 1.8 m
VGA cable
Shielded
Length
1.8 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
Grey
P/N: CDP2VGA, CDP2VGAUCPW, MDP2VGAAMM2M, MDP2VGAAMM3M, SV231DVGAU2A, SV431DVGAU2A, USB32VGAEH3
VGA cable
Shielded
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
1.8 m
Grey
Connector
