Connect your Mini USB devices, with the cable out of the way. The USB2HABM6RA 6ft USB to Right Angle Mini USB Cable provides a high quality connection between your Mini USB 2.0 mobile devices (smartphones, GPS, digital cameras, portable hard drives, etc.) and your PC or Mac computer, for everyday tasks such as charging, data synchronization or file transfers.
The right-angled Mini USB connector allows you to access your Mini USB devices, while keeping the cable out of the way, and stress away from the port.
As an alternative, StarTech.com also offers a 6ft USB A to Left Angle Mini B Cable (USB2HABM6LA), which provides the same convenience as this right-angled cable, but allows you to connect to your Mini USB device from the opposite direction.
- StarTech.com 6 ft. (1.8 m) Right Angle USB to Mini USB Cable - USB 2.0 A to Right Angle Mini B - Black - Mini USB Cable (USB2HABM6RA) - USB cable - USB to mini-USB Type B - 1.8 m
- USB cable
- 90° connector, right-angled connector
- Length
- 1.8 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- Mini-USB Type B - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: SV565HDIP
- USB cable
- American Wire Gauge (AWG)
- 28
- Length
- 1.8 m
- Black
- Connector
- USB / USB 2.0, RoHS
- Designed For
- P/N: SV565HDIP
StarTech.com Mountable 4 Port Rugged Industrial USB Hub | In Stock | £63.70 |
StarTech.com 1 ft Panel Mount USB Cable B to B - F/M | In Stock | £6.59 |
StarTech.com Mountable Rugged Industrial 7 Port USB Hub | In Stock | £83.34 |
StarTech.com 6in Mini USB 2.0 Cable - A to Mini B | In Stock | £4.05 |
StarTech.com 3 ft Panel Mount USB Cable B to B - F/M | In Stock | £5.69 |
