StarTech.com 6 ft Mini USB Cable - A to Mini B
Quicklinx: 401MWS00 Mfr#: USB2HABM6
Length: 1.8m
More than 50 in stock
£3.17 ex VAT
£3.80 inc VAT
Connect your (USB Mini) portable device to a host computer through a standard USB 2.0 type-A slot. This USB 2.0 cable provides a high-quality replacement for the cable that came with your Mini USB mobile device. Or, you can keep it as a spare while traveling.
The cable is perfect for connecting devices such as your smartphone, GPS, digital camera, or portable hard drive, to your PC or Mac computer for everyday tasks such as charging, data synchronization or file transfers.
StarTech.com 6 ft Mini USB Cable - A to Mini B - USB cable - 1.8 m
USB cable
Length
1.8 m
Connector
4 pin USB Type A - male
Connector (Second End)
Mini-USB Type B - male
USB / USB 2.0
P/N: SAT1810U2, IPUSB2HDMI, SLMSOPTB, PEXUSB7LP, UNI2510U2V, S2510PESAT, SAT2510U2F, SAT2510U2S, SAT2510BU2, NBCOOLERPRGB, SAT2510U2REM, NBCOOLERPRO, SATCAS25OTGB, SATCAS35U2GB, SATCASE25OTG, SATCASE35U2, IDECASE25U2B
USB cable
Length
1.8 m
Connector
USB / USB 2.0
StarTech.com 1.8in USB to Micro SATA Hard Drive Enclosure, 2.5in Black USB 2.0 External Hard Drive Enclosure for SATA HDD, 2.5in SATA External Hard Drive Enclosure for 3.5/5.25 Front Drive Bay, 2.5in Silver Power eSATA to SATA External Hard Drive Enclosure w/ OTB, 2.5in Silver USB 2.0 One Button IDE External Hard Drive Enclosure, 2.5in Tool-less USB 2.0 to IDE SATA External Hard Drive Enclosure, 2.5in USB FireWire SATA External Hard Drive Enclosure, 7 Port PCI Express Low Profile High Speed USB 2.0 Adapter Card, Aluminum Dual Fan Laptop Cooler with USB Hub and Card Reader, Ethernet or USB to HDMI Converter, Extra 2.5in SATA Hard Drive Enclosure for SAT2510U2REM, USB to Slimline SATA CD/DVD Optical Drive Enclosure , StarTech.com InfoSafe 2.5" SATA to USB 2.0 On-The-Go Drive Enclosure, 2.5" USB 2.0 IDE Drive Enclosure, 2.5" USB 2.0 SATA Drive Enclosure, 3.5" USB 2.0 to SATA Drive Enclosure
401M StarTech.com 6 ft Mini USB Cable - A to Mini B In Stock £3.17
401M StarTech.com 3 ft Mini USB 2.0 Cable - A to Mini B In Stock £3.18
401M StarTech.com 10 ft USB 2.0 Cable - USB A to Mini B In Stock £3.37
401M StarTech.com Mini USB to Micro USB Adapter In Stock £4.96
Length: 1.8m
Price Range Ex VAT: 0 - 50
