Connect your (USB Mini) portable device to a host computer through a standard USB 2.0 type-A slot. This USB 2.0 cable provides a high-quality replacement for the cable that came with your Mini USB mobile device. Or, you can keep it as a spare while traveling.
The cable is perfect for connecting devices such as your smartphone, GPS, digital camera, or portable hard drive, to your PC or Mac computer for everyday tasks such as charging, data synchronization or file transfers.
- StarTech.com 6 ft Mini USB Cable - A to Mini B - USB to Micro b - 6ft USB to Micro Cable - 6ft Micro USB Cable (USB2HABM6) - USB cable - USB to mini-USB Type B - 1.8 m
- USB cable
- Length
- 1.8 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- Mini-USB Type B - male
- USB / USB 2.0
- Limited lifetime warranty
- Designed For
- P/N: BOX4CABLE, BOX4HDECP, BOX4HDECP2, DPBOOST, HDBOOST4K, HDBOOST4K2, MOD4AVHD, MOD4AVHDBT, MOD4DOCKACPD, NOTECONS01, NOTECONS02, NOTECONS02X, SATDOCK25U, ST121HDBTU, ST121USBHD, ST121WHD2, ST124HDBT, SV231USBLC, SV565HDIP, USB1000IP, USBEXTAA10BK, USBEXTAA3BK, USBEXTAA6BK, USBPLATE4
- USB cable
- Length
- 1.8 m
- Connector
- USB / USB 2.0
- Designed For
StarTech.com 6 ft Mini USB Cable - A to Mini B | In Stock | £3.18 |
StarTech.com 10 ft USB 2.0 Cable - USB A to Mini B | In Stock | £3.35 |
StarTech.com Mini USB to Micro USB Adapter | In Stock | £4.98 |
