Connect your VGA monitor to a mini DisplayPort-equipped computer using a single cable. The MDP2VGAMM6 6-foot mini DisplayPort to VGA cable is a cost-effective mini DisplayPort to VGA link that lets you connect a VGA monitor to a PC or Mac with a mini DisplayPort output - saving the expense of upgrading the monitor for compatibility.
Compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port. This all-in-one, easy to use Mini DisplayPort/VGA cable requires no additional converters or adapters, and no driver or software installation.
- StarTech.com 6 ft. (1.8 m) Mini Displayport to VGA Cable - 1920x1200 / 1080p - Thunderbolt Compatible - VGA Monitor Cable (MDP2VGAMM6) - video converter - black
- Video converter
- Max Resolution
- 1920 x 1200
- 1 x DisplayPort output - Mini DisplayPort , 1 x VGA input - 15 pin HD D-Sub (HD-15)
- Enclosure Colour
- Black
- 3-year warranty
- Video converter
- Max Resolution
- 1920 x 1200
- 1 x DisplayPort output - Mini DisplayPort - male , 1 x VGA input - 15 pin HD D-Sub (HD-15) - male
- Active cable (signal regeneration), Thunderbolt port compatible
- Cables Included
- 1 - 1.8 cm
- FCC, RoHS, WEEE
- 90 g
- Enclosure Colour
- Black
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 20 - 80%
