StarTech.com 6 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - White
Quicklinx: 8XCHWS00 Mfr#: MDP2DVIMM6W
Connect a DVI display to a Mini DisplayPort-equipped PC or MAC over a 6 foot distance - White. The MDP2DVIMM6WMini DisplayPort to DVI Adapter Cable lets you directly connect your Mini DP video source (Desktop PC, Laptop, Ultrabook, etc.) to a DVI monitor or projector, eliminating the expense of having to upgrade to a Mini DisplayPort-capable monitor.
The adapter cable is 6 feet (1.8 m) in length, and features male-to-male connectors, allowing you to connect your Mini DisplayPort source directly to a DVI display with no additional cabling required.
Compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port, the adapter supports display or projector resolutions up to 1920x1200 (WUXGA).
MDP2DVIMM6Wis a passive adapter that requires a dual-mode DisplayPortport (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
StarTech.com 6 ft Mini DisplayPort to DVI Adapter Cable - Mini DP to DVI Video Converter - MDP to DVI Cable for Mac / PC 1920x1200 - White (MDP2DVIMM6W) - DisplayPort cable - 1.82 m
DisplayPort cable
Thumbscrews
Length
1.82 m
Connector
Mini DisplayPort - male
Connector (Second End)
DVI-D - male
FCC, RoHS
White
Image Colour Disclaimer
The displayed product image may be a different colour
3-year warranty
DisplayPort cable
Thumbscrews
Length
1.82 m
White
Connector
24+1 pin digital DVI - male
FCC, RoHS
3-year warranty
8XCH StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £12.84
8XCH StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M In Stock £31.26
8XCH StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M In Stock £23.82
8XCH StarTech.com Mini DisplayPort to DVI Video Adapter Converter In Stock £11.28
8XCH StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £10.86
8XCH StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £15.80
8XCH StarTech.com 6 ft Mini DisplayPort to DVI Cable - M/M In Stock £26.80
8XCH StarTech.com Mini DisplayPort to DVI Video Adapter Converter - Black Mini DP to DVI - 1920x1200 In Stock £11.09
8XCH StarTech.com 3 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black In Stock £13.67
8XCH StarTech.com 6 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black In Stock £14.80
8XCH StarTech.com 10 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 Black In Stock £21.85
8XCH StarTech.com 6 ft Mini DisplayPort to DVI Active Adapter Converter Cable - 2560x1600 – Black In Stock £24.24
