Product
StarTech.com 6 ft Micro USB Cable A to Right Angle Micro B
Quicklinx: 98F0WS00 Mfr#: UUSBHAUB6RA
Length: 1.8m
42 in stock
£4.78 ex VAT
£5.73 inc VAT
Standard delivery Delivered within 3-5 working days
Charge or sync your Micro-B USB devices with the cable out of the way. The UUSBHAUB6RA 6-foot USB-A to Micro-B Cable provides a high quality connection between Micro USB-equipped USB 2.0 mobile devices (such as BlackBerry or Android-based smart phones, digital cameras, PDAs, Tablet PC devices and GPS systems, etc.) and a USB-capable computer, for everyday tasks such as data synchronization, file transfers and charging.
The right-angled Micro USB connector positions the cable in such a way that it allows you to easily access your mobile digital device in both portrait and landscape mode, even while charging.
As an alternative, StarTech.com also offers a 6ft USB A to Left Angle Micro B Cable (UUSBHAUB6LA), which provides the same convenience as this right-angled cable but allows you to connect to your USB Micro-B devices from the opposite direction.
StarTech.com 6 ft Micro USB Cable - A to Right Angle Micro B - USB cable - 1.8 m
USB cable
90° connector
Length
1.8 m
Connector
4 pin USB Type A - male
Connector (Second End)
5 pin Micro-USB Type B - male
P/N: PEXUSB7LP
USB cable
90° connector
Length
1.8 m
Connector
RoHS
StarTech.com 7 Port PCI Express Low Profile High Speed USB 2.0 Adapter Card
Length: 1.8m
Price Range Ex VAT: 0 - 50
