Connect an HDMI-enabled output device to a DVI-D display, or a DVI-D output device to an HDMI-capable display. The HDMIDVIMM6 6-foot HDMI to DVI-D cable enables you to connect a DVI-D video card (or other DVI-D output device) to a display that incorporates HDMI technology; the cable supports bi-directional operation that also allows the reverse configuration, delivering digital video from an HDMI-enabled output to a DVI-D capable display.
A valuable addition to any digital signage, multimedia or home theater application, this high performance cable is designed to provide the best quality picture available through either HDMI technology or DVI digital connections.
- StarTech.com 6ft HDMI to DVI D Adapter Cable - Bi-Directional - HDMI to DVI or DVI to HDMI Adapter for Your Computer Monitor (HDMIDVIMM6) - video cable - 1.83 m
- Cable
- Video cable
- Length
- 1.83 m
- Black
- Connector
- HDMI - male
- Connector (Second End)
- DVI-D - male
- Limited lifetime warranty
- Designed For
- P/N: SP123DP2DVI, HDMI2VGA, HDMI2HDMI, ST121HDMIT
- Cable Type
- Video cable
- Length
- 1.83 m
- Black
- Connector
- 19 pin HDMI Type A - male
- 18+1 pin digital DVI (Single-Link) - male
- Limited warranty - lifetime
- Designed For
- StarTech.com HDMI to VGA Video Adapter Converter w/ Audio HD to VGA Monitor, HDMI Video Extender over Cat 5, TripleHead DisplayPort to DVI Multi Monitor Adapter
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £7.08 |
StarTech.com HDMI to DVI-D Video Cable Adapter - F/M | In Stock | £7.46 |
StarTech.com HDMI to DVI-D Video Cable Adapter - M/F | In Stock | £7.46 |
StarTech.com 10 ft HDMI to DVI-D Cable - M/M | In Stock | £8.58 |
StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female | In Stock | £7.57 |
