StarTech.com 6 ft HDMI to DVI-D Cable - M/M
Quicklinx: 4JDRWS00 Mfr#: HDMIDVIMM6
Type: HDMI
Length: 1.83m
Select:
39 in stock
£7.26 ex VAT
£8.71 inc VAT
Connect an HDMI-enabled output device to a DVI-D display, or a DVI-D output device to an HDMI-capable display. The HDMIDVIMM6 6-foot HDMI to DVI-D cable enables you to connect a DVI-D video card (or other DVI-D output device) to a display that incorporates HDMI technology; the cable supports bi-directional operation that also allows the reverse configuration, delivering digital video from an HDMI-enabled output to a DVI-D capable display.
A valuable addition to any digital signage, multimedia or home theater application, this high performance cable is designed to provide the best quality picture available through either HDMI technology or DVI digital connections.
StarTech.com 6ft HDMI to DVI D Adapter Cable - Bi-Directional - HDMI to DVI or DVI to HDMI Adapter for Your Computer Monitor (HDMIDVIMM6) - video cable - 1.83 m
Cable
Video cable
Length
1.83 m
Connector
HDMI - male
Connector (Second End)
DVI-D - male
P/N: BNDDKT30CAHV, BOX4CABLE, DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DKT30CDVPD, DKWG30DPHPD, DKWG30DPHPDU, MSTCDP122HD, RKCOND17HD, ST121HD20FXA, ST121HDBTSC, ST121WHDS, ST12MHDLAN4K, ST12MHDLAN4R, ST12MHDLNHK, ST12MHDLNHR, USB32HD2, USBC2DVCAPRO, UVCHDCAP, VID2HDCON2, VS424HD4K60
Cable Type
Video cable
Length
1.83 m
Connector
19 pin HDMI Type A - male
18+1 pin digital DVI (Single-Link) - male
Limited warranty - lifetime
P/N: BNDDKT30CAHV, BOX4CABLE, DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DKT30CDVPD, DKWG30DPHPD, DKWG30DPHPDU, DP2DVI, DP2DVI2, DP2DVIS, DP2HD4KS, DP2HDMI, DP2HDMI2, DP2HDMIADAP, DVI92030202L, DVISPL1DD, HDBOOST, HDMI2HDMI, HDMI2VGA, HDMIPNLFM3, HDVGADP2HD, MDP2DVI, MDP2DVI3, MDP2DVIS, MDP2DVIW, MDP2HD4KS, MDP2HDMI, MDP2HDW, MHD2HDF11, MSTCDP122HD, MSTDP123HD, MSTMDP123HD, MSTP3MDPUGBK, MSTS3MDPUGBK, RKCOND17HD, ST121HD20FXA, ST121HDBTSC, ST121HDFXA, ST121HDWP, ST121SHD30, ST121SHD50, ST121USBHD, ST121UTPHD2, ST121WHD2, ST121WHDS, ST122DVIA, ST122HD4K, ST122HD4KU, ST122HDMI2, ST122HDMILE, ST124DVIA, ST124HD4K, ST124HDMI2, ST128HDMI2, ST12MHDLAN, ST12MHDLAN4K, ST12MHDLAN4R, ST12MHDLANRX, ST12MHDLANU, ST12MHDLANUR, ST12MHDLNHK, ST12MHDLNHR, ST424HDBT, STDHVHDBT, STHDBTRX, SV831DVIU, TB32HD2, USB2DVIE3, USB2DVIPRO2, USB2HDCAPS, USB32DVCAPRO, USB32DVIEH, USB32DVIPRO, USB32HD2, USB32HD4K, USB32HDDVII, USB32HDEH, USB32HDES, USB32HDPRO, USB3SMDOCKHV, USBC2DVCAPRO, UVCHDCAP, VGA2HD2, VID2HDCON, VID2HDCON2, VS221HD2VGA, VS221HD4K, VS221HD4KA, VS221HDQ, VS221VGA2HD, VS222HD4K, VS222HDQ, VS420RDVIA, VS421HD4K, VS421HD4KA, VS421HDPIP, VS424HD4K60, VS424HDPIP, VS440HDMI, VS721MULTI, WIFI2HD2, WIFI2HDMC, WIFI2HDVGA
4JDR StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.26
4JDR StarTech.com HDMI to DVI-D Video Cable Adapter - F/M In Stock £7.65
4JDR StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £7.66
4JDR StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female In Stock £7.77
Type: HDMI
Length: 1.83m
Price Range Ex VAT: 0 - 50
