StarTech.com 6 ft DVI to Coax High Resolution VGA Monitor Cable
Quicklinx: 3ZKPWS00 Mfr#: DVIVGAMM6
Select:
  • 2m
This 6ft DVI to VGA Monitor Cable features a DVI (analog) male connector and a VGA (High Density D-Sub) male connector, providing a cost-effective way to connect an analog or dual mode Flat Panel Display to a PC or Mac computer with a DVI Analog Video Card.
The 6ft DVI to VGA Monitor cable is expertly designed and constructed of only high quality materials.
StarTech.com 6 ft DVI to Coax High Resolution VGA Monitor Cable - DVI to VGA connector - 6ft DVI to VGA Converter (DVIVGAMM6) - video cable - 1.8 m
Video cable
Length
1.8 m
Connector
HD-15 (VGA) - male
Connector (Second End)
DVI-A - male
FCC
P/N: SV431DD2DU3A
Video cable
Length
1.8 m
Connector
12+5 pin analogue DVI - male
FCC
P/N: SV431DD2DU3A
