StarTech.com 6 ft DVI-I Dual Link Digital Analog Monitor Extension Cable M/F
Quicklinx: 76M1WS00 Mfr#: DVIIDMF6
Type: DVI
Length: 1.83m
£8.71 ex VAT
£10.45 inc VAT
Extend your DVI-I (dual link) connection by 6ft. The DVIIDMF6 DVI-I Dual-Link Digital Analog Monitor Extension Cable allows you to extend the connection distance between your DVI-I devices by up to 6-feet.
The dual link cable supports resolutions of up to 2560x1600 and transmission rates of up to 9.9 Gbits/sec, and is fully compliant with DVI DDWG standards.
StarTech.com 6ft DVI-I Dual Link Digital Analog Monitor Extension Cable M/F - DVI extension cable - 1.83 m
DVI extension cable - dual link
Length
1.83 m
Connector
DVI-I - male
Connector (Second End)
DVI-I - female
P/N: ST121UTPDVEU, USB2DVIPRO, ST121UTPDVGB, USB2DVIE, ST121UTPDVI, DVIEQ, USB2DVI, AGPVID5500A
DVI extension cable
TMDS Links
Dual link
Length
1.83 m
Connector
24+5 pin combined DVI - male
24+5 pin combined DVI - female
StarTech.com DVI Video Extender Equalizer, DVI Video Extender over Cat5, Professional USB to DVI Multi Monitor Video Adapter, USB DVI External Multi Monitor Video Adapter - Graphics adapter - Hi-Speed USB - 16 MB - DVI, USB DVI VGA External Multi Monitor Video Adapter - Graphics adapter - Hi-Speed USB - 16 MB - DVI
Type: DVI
Length: 1.83m
Price Range Ex VAT: 0 - 50
