StarTech.com 6 ft DVI-I Dual Link Digital Analog Monitor Cable M/M
Quicklinx: 3ZKWWS00 Mfr#: DVIIDMM6
Type: DVI
Length: 1.83m
Select:
More than 50 in stock
£8.06 ex VAT
£9.67 inc VAT
Provides a high speed, crystal clear connection between your DVI devices. The DVIIDMM6 6ft DVI-I Dual Link cable features 2 male DVI-I (29-pin) connectors and provides a reliable connection between your desktop or laptop computer and a DVI-I monitor or projector.
The 6ft DVI-I male to male cable supports resolutions of up to 2560x1600 and transmission rates of up to 9.9 Gbits/sec, and is fully compliant with DVI DDWG standards.
StarTech.com 6 ft DVI-I Dual Link Digital Analog Monitor Cable M/M - DVI cable - 1.83 m
DVI cable - dual link
Length
1.83 m
Connector
DVI-I - male
Connector (Second End)
DVI-I - male
P/N: ST121UTPDVEU, USB2DVIPRO, SV431DD2DUA, SV231DD2DUA, ST121UTPDVGB, USB2DVIE, SV431DVIDDU, SV231DVIDDU, ST121UTPDVI, USB2DVI, AGPVID5500A
DVI cable
TMDS Links
Dual link
Length
1.83 m
Connector
24+5 pin combined DVI - male
StarTech.com 4 Port Dual DVI USB KVM Switch w/ Audio & USB Hub, DVI Video Extender over Cat5, Professional USB to DVI Multi Monitor Video Adapter, USB DVI External Multi Monitor Video Adapter - Graphics adapter - Hi-Speed USB - 16 MB - DVI, USB DVI VGA External Multi Monitor Video Adapter - Graphics adapter - Hi-Speed USB - 16 MB - DVI
Type: DVI
Length: 1.83m
Price Range Ex VAT: 0 - 50
