StarTech.com 6 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F
Quicklinx: 3ZKBWS00 Mfr#: MXT101HQ
Type: SVGA
Length: 1.8m
48 in stock
£5.80 ex VAT
£6.96 inc VAT
This 6ft High Resolution VGA Extension Cable is designed to provide the highest video quality possible through VGA.
Ideally suited for high resolution VGA applications, this high quality male to female coaxial VGA extension cable helps to eliminates picture "ghosting" and fuzzy images inherent to non-coaxial cables, and provides superior EMI interference protection by using ferrite cores near the connector ends.
StarTech.com 6 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F - 6ft VGA Extension Cable (MXT101HQ) - VGA extension cable - 1.8 m
VGA extension cable
Coaxial
Molded
Length
1.8 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - female
P/N: AGPVID5500A, DP2VGAMM6, DP2VGAMM6B, DS128, DSRXL, HD2VGAMM6, MXT101MM, ST1212T, ST121REU, ST121RGB, ST122LEU, ST122PROEU, ST122PROGB, ST122UTPA, ST122UTPAEU, ST122UTPAGB, ST122UTPAL, ST122W, ST124L, ST124PROEU, ST124W, ST128L, STUTPRXL, SV231USBLC, SV431USB, SVUSB2N1_6, USBVGADOCK2, VGABNCMF1
VGA extension cable
Coaxial
Plated Connector
Nickel
Molded
Length
1.8 m
Connector
15 pin HD D-Sub (HD-15) - female
P/N: AGPVID5500A, DP2VGAMM6, DP2VGAMM6B, DS128, DSRXL, HD2VGAMM6, MXT101MM, ST1212T, ST121REU, ST121RGB, ST122LEU, ST122PRO, ST122PROEU, ST122PROGB, ST122UTPA, ST122UTPAEU, ST122UTPAGB, ST122UTPAL, ST122W, ST124L, ST124PRO, ST124PROEU, ST124W, ST128L, ST128PRO, STUTPRXL, SV231USBLC, SV431USB, SVUSB2N1_6, USBVGADOCK2, VGABNCMF1
Resources
The following resources are available for the StarTech.com 6 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F
Type: SVGA
Length: 1.8m
Stock Status: In stock
