StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M
Quicklinx: 3ZK2WS00 Mfr#: MXT101MMHQ
Type: VGA
Length: 1.8m
More than 50 in stock
£6.05 ex VAT
£7.26 inc VAT
This 6ft High Resolution VGA Monitor Cable is designed to provide the highest video quality possible through VGA. Ideally suited for high resolution VGA applications, this high quality male to male coaxial VGA cable eliminates picture "ghosting" and fuzzy images inherent to non-coaxial cables, and provides superior EMI interference protection by using ferrite cores near the connector ends.
StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable -M/M - VGA cable - 1.8 m
VGA cable
Triple shielded twisted pair coaxial
Molded, ferrite bead
Length
1.8 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
P/N: RKCONS2001GB, ST124UTPEAGB, ST128UTPEAGB, STUTPEALRGB, ST122UTPAEU, ST121UTPMINI, RACKCONS2001, VGA2TV2WAY2, USBVGADOCK2, USB2VGADVI, USBVGADOCKGB, ST121RGB, ST121EXTGB, ST1214TGB, ST128UTPEA, STUTPEALR, ST124UTPEA, VS410RVGAA, USBVGADOCK, ST121R, ST121EXT, ST1214T, AGPVID5500A, ST122UTPAGB
VGA cable
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
1.8 m
Connector
StarTech.com 2 Port DVI PS/2 KVM Switch, 2 Port Matrix High Resolution VGA Video Splitter, 2 Port VGA Dual Monitor KVM Switch with PS/2, 2 Way High Resolution HDTV VGA Video Converter with Scaler, 2 Way VGA HDTV Video Converter with Scaler, 4 Port High Resolution VGA Video Switch with Remote, 4 Port VGA Dual Monitor KVM Switch with PS/2, 4 Port VGA Matrix Video Switch - 250 MHz, 4 Port VGA Video Audio Switch with RS232 control, 4 Port VGA Video Extender over Cat 5 (UTPE Series), 4-in-1 USB VGA Adapter and Docking Station, 8 Port VGA and Audio over Cat 5 Video Extender, 8 Port VGA Video Extender over Cat 5 (UTPE Series), 8 Port VGA Video Selector Switch, Component / Composite / S-Video to VGA / HDTV Scaler / Converter, Composite and S-Video to VGA Video Converter, High Res RackMount LCD Console for 19" Rack, Mini VGA Video and Audio Extender over Cat5, USB VGA and DVI Dual Port External Video Adapter, VGA to DVI-I Video Converter with Scaler, VGA to HDMI Video Converter with Audio, VGA Video Extender over Cat 5 Remote Receiver with Audio, VGA Video Extender over Cat 5 with Audio , StarTech.com Converge A/V 4 Port VGA and Audio over Cat 5 Video Extender, 4 Port VGA over Cat5 UTP Extender, VGA over Cat5 UTP Receiver, VGA over Cat5 UTP Receiver/Extender , StarTech.com UTP VGA/Multisync Video Extender
3ZK2 StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £6.05
3ZK2 StarTech.com 20 ft Coax High Resolution Monitor VGA Cable HD15 M/M In Stock £9.79
3ZK2 StarTech.com 1 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £4.72
Type: VGA
Length: 1.8m
Price Range Ex VAT: 0 - 50
