StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M
Quicklinx: 3ZK2WS00 Mfr#: MXT101MMHQ
Type: VGA
Length: 1.8m
More than 50 in stock
£5.82 ex VAT
£6.98 inc VAT
This 6ft High Resolution VGA Monitor Cable is designed to provide the highest video quality possible through VGA. Ideally suited for high resolution VGA applications, this high quality male to male coaxial VGA cable eliminates picture "ghosting" and fuzzy images inherent to non-coaxial cables, and provides superior EMI interference protection by using ferrite cores near the connector ends.
StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M - 6ft HD15 to HD15 Cable (MXT101MMHQ) - VGA cable - 1.8 m
VGA cable
Triple shielded twisted pair coaxial
Molded, ferrite bead
Length
1.8 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
P/N: BNDDKTCHVPRS, BOX4HDECP2, CDP2DPVGA, CDP2HDVGA, CDP2MDPVGA, CDP2VGAFC, CDPVDHDMDP2G, CDPVDHDMDPRG, CDPVDHDMDPSG, CDPVDHMDPDP, CDPVGDVHDBP, DKT30CHVCM, DKT30CHVGPD, DKT30CVAGPD, DP2VGA3X5, MOD4AVHD, MOD4AVHDBT, PEXHDCAP60L2, RKCOND17HD, ST121HDBTSC, USB32HDVGA, USBC2VGCAPRO, VID2VGATV3
VGA cable
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
1.8 m
Connector
P/N: AGPVID5500A, BNDDKTCHVPRS, BOX4CABLE, BOX4HDECP, BOX4HDECP2, CAB1631HD, CAB831HD, CAB831HDU, CABCONS1716I, CDP2DPVGA, CDP2HDVGA, CDP2MDPVGA, CDP2VGA, CDP2VGAFC, CDP2VGASA, CDP2VGAUACP, CDP2VGAUCP, CDP2VGAUCPW, CDPVDHDMDP2G, CDPVDHDMDPRG, CDPVDHDMDPSG, CDPVDHMDPDP, CDPVGDVHDB, CDPVGDVHDBP, CDPVGDVHDMDP, CPNT2VGAA, DK30BACDD, DKT30CHV, DKT30CHVCM, DKT30CHVGPD, DKT30CHVW, DKT30CVAGPD, DP2HDVGA, DP2VGA, DP2VGA2, DP2VGA3, DP2VGA3X5, DP2VGAA, DP2VGAAMM2M, DP2VGAAMM3M, DP2VGDVHD, DS128, DS154, DSRXL, DVI2VGA, DVI2VGACON, DVI2VGAE, DVI92030202L, DVISPL1VV, DVIVGAMF, DVIVGAMFBK, HD2DPVGADVI, HD2VGAA2, HD2VGAE2, HD2VGAMICRA, HD2VGAMICRO, HDMI2VGA, HDVGADP2HD, IPUSB2VGA2, MCHD2VGA, MCHD2VGAE2, MDP2HDVGA, MDP2HDVGAW, MDP2VGA, MDP2VGA2, MDP2VGAW, MDP2VGDVHD, MDP2VGDVHDW, MDPVGDVHD4K, MNHD2VGAE2, MOD4AVHD, MOD4AVHDBT, MSTP3MDPUGBK, MSTS3MDPUGBK, PEXHDCAP2, PEXHDCAP60L2, RACKCONS1908, RACKCONS1916, RKCOND17HD, SLMPT2VGA, ST1212T, ST1214T, ST1216PRO, ST1218T, ST121EXT, ST121HDBTSC, ST121R, ST121REU, ST121RGB, ST121UTP, ST121UTP232, ST121UTPEP, ST122LE, ST122LEA, ST122PRO, ST122PROA, ST122UTPA, ST122UTPAEU, ST122UTPAGB, ST122UTPAL, ST122VGA, ST122VGAU, ST122W, ST124PRO, ST124UTPEA, ST124W, ST128PRO, ST222MX, ST222MXA, ST224MX, ST424MX, STDHVHDBT, STUTPEALR, STUTPRXL, STUTPWALLA, SV1631DUSBUK, SV221NANOU, SV231DDUSB, SV231DDVDUA, SV231DVGAU2A, SV231UAF, SV231USB, SV231USBLC, SV431DDVDUA, SV431DVGAU2A, SV431USB, SV565DUTPU, SV565USAGB, SV565UTP, SV565UTPU, SV565UTPUL, USB2VGAE2, USB2VGAE3, USB2VGAPRO2, USB32HDVGA, USB32VGAEH, USB32VGAEH3, USB32VGAES, USB32VGAPRO, USB32VGAV, USB32VGCAPRO, USB3HDCAP, USB3SDOCKDD, USB3SDOCKHDV, USBC2VGCAPRO, USBVGADOCK2, VGA2HD2, VGA2HDPRO2, VGA2VID, VGAPLATE, VGASPL1VV, VID2VGATV, VID2VGATV2, VID2VGATV3, VS221HD2VGA, VS221VGA2HD, VS410RVGAA, VS721MULTI, WIFI2HDVGA
3ZK2 StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £5.82
3ZK2 StarTech.com 20 ft Coax High Resolution Monitor VGA Cable HD15 M/M In Stock £9.79
3ZK2 StarTech.com 1 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £5.99
Type: VGA
Length: 1.8m
Price Range Ex VAT: 0 - 50
