StarTech.com 6 ft Coax High Resolution 90 degree Down Angled VGA Monitor Cable - HD15 M/M
Quicklinx: 6LC2WS00 Mfr#: MXT101MMHD6
Type: VGA
Length: 1.8m
Select:
43 in stock
£6.57 ex VAT
£7.88 inc VAT
This 6ft High Resolution Video VGA Cable (90 degree) is designed to provide the highest video quality possible through a VGA connection and is specifically constructed to accommodate tight installation spaces.
The high quality, shielded coax VGA cable features a 90 degree down-angled plug, which requires only 32.4mm (1.27") of space to make the video connection.
More than suitable for high-res VGA applications (1280x1024 resolution and above), the 90 degree VGA cable eliminates picture "ghosting" and fuzzy images that are common with non-coaxial cables, and provides superior EMI interference protection using ferrite cores near the connector ends.
StarTech.com "6 ft Coax High Resolution 90° Down Angled VGA Monitor Cable - HD15 M/M (MXT101MMHD6)" - VGA cable - 1.8 m
VGA cable
90° connector, ferrite bead
Length
1.8 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
RoHS
P/N: CDP2VGA, CDP2VGAFC, SV221NANOU, SV231UAF, VGAPLATE
VGA cable
American Wire Gauge (AWG)
28
Length
1.8 m
Connector
RoHS
6LC2 StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £5.82
6LC2 StarTech.com 10 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £10.17
6LC2 StarTech.com 6 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £5.82
6LC2 StarTech.com DVI to VGA Cable Adapter - M/F In Stock £4.87
6LC2 StarTech.com 3 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £6.38
6LC2 StarTech.com 35 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £24.14
6LC2 StarTech.com Right Angle VGA to VGA Cable Adapter Type 1 - M/F In Stock £6.13
6LC2 StarTech.com Right Angle VGA to VGA Cable Adapter Type 2 - M/F In Stock £6.13
Type: VGA
Length: 1.8m
Price Range Ex VAT: 0 - 50
