This 6ft High Resolution Video VGA Cable (90 degree) is designed to provide the highest video quality possible through a VGA connection and is specifically constructed to accommodate tight installation spaces.
The high quality, shielded coax VGA cable features a 90 degree down-angled plug, which requires only 32.4mm (1.27") of space to make the video connection.
More than suitable for high-res VGA applications (1280x1024 resolution and above), the 90 degree VGA cable eliminates picture "ghosting" and fuzzy images that are common with non-coaxial cables, and provides superior EMI interference protection using ferrite cores near the connector ends.
- StarTech.com "6 ft Coax High Resolution 90° Down Angled VGA Monitor Cable - HD15 M/M (MXT101MMHD6)" - VGA cable - 1.8 m
- VGA cable
- 90° connector, ferrite bead
- Length
- 1.8 m
- Connector
- HD-15 (VGA) - male
- Connector (Second End)
- RoHS
- Black
- Limited lifetime warranty
- Designed For
- P/N: CDP2VGA, CDP2VGAFC, SV221NANOU, SV231UAF, VGAPLATE
- VGA cable
- American Wire Gauge (AWG)
- 28
- Length
- 1.8 m
- Black
- Connector
- 15 pin HD D-Sub (HD-15) - male
- RoHS
- Designed For
StarTech.com Slimline Adapter HDDB15 F/F | In Stock | £5.07 |
StarTech.com DVI to VGA Cable Adapter - M/F | In Stock | £5.42 |
StarTech.com Right Angle VGA to VGA Cable Adapter Type 1 - M/F | In Stock | £7.06 |
StarTech.com Right Angle VGA to VGA Cable Adapter Type 2 - M/F | In Stock | £7.03 |
