StarTech.com 6 ft Coax HD15 VGA to 5 BNC Monitor Cable – M/M
Quicklinx: 3ZJLWS00 Mfr#: VGABNC5
Connect your PC's VGA/SVGA port to a monitor with 5 BNC connectors. This 6ft Coax VGA Monitor Cable provides a VGA (HDDB15) connecter and a BNC male connector, allowing you to connect your PC VGA/SVGA port to a monitor with 5 BNC connectors.
StarTech.com 6 ft. (1.8 m) VGA to BNC Cable - HD15 VGA to 5 BNC - Coaxial High Resolution - Male/Male - BNC Cable (VGABNC5) - VGA cable - 1.8 m
VGA cable
Coaxial
Length
1.8 m
Connector
HD-15 (VGA) - male
Connector (Second End)
5 x BNC - male
VGA cable
Coaxial
Length
1.8 m
Connector
5 x BNC - male
