StarTech.com 6 ft Cisco Console Rollover Cable - RJ45 Ethernet M/M
Quicklinx: 7P1MWS00 Mfr#: ROLLOVERMM6
Length: 1.8m
Colour: Blue
Hurry, only 1 left in stock!
£5.45 ex VAT
£6.54 inc VAT
Connect your computer to your Cisco router, server, or network equipment. This 6ft Cisco Console Cable/Rollover cable is a cost-effective replacement cable which enables you to connect your computer to your Cisco router, server, or network equipment. This durable Cisco Console Cable is a direct replacement cable that conforms to the Yost serial device wiring standard.
Expertly designed and constructed of only the highest quality materials, the Cisco Console Rollover cable delivers maximum dependability.
StarTech.com Cisco Console Rollover Cable - RJ45 Ethernet - Network cable - RJ-45 (M) to RJ-45 (M) - 6 ft - molded, flat - blue - ROLLOVERMM6 - network cable - 1.8 m - blue
Network cable
Wires per Cable
8 wires
Molded, flat
Length
1.8 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Network Cable Type
Network cable
Jacket Material
PVC
American Wire Gauge (AWG)
26
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Molded, flat
Length
1.8 m
Blue
Connector
RJ-45 - male
RJ-45 - male
RoHS
7P1M StarTech.com 6 ft RJ45 to DB9 Cisco Console Management Router Cable - M/F In Stock £16.51
7P1M StarTech.com Cisco Console Rollover Adapter for RJ45 Ethernet Cable M/F In Stock £5.29
7P1M StarTech.com 6 ft Cisco Console Rollover Cable - RJ45 Ethernet M/M In Stock £5.45
Length: 1.8m
Colour: Blue
Price Range Ex VAT: 0 - 50
