Extend your USB 3.0 SuperSpeed cable by up to an additional 6 feet. The USB3SEXT6BK SuperSpeed USB 3.0 extension cord (A-A), offers a durable, high quality connection that harnesses the full capability of the USB 3.0 standard.
Designed for next-generation SuperSpeed USB device connections, this USB 3.0 male to female cable extends a USB 3.0 cable connection by 6-feet, and delivers a throughput of up to 5Gbps when used with a USB 3.0 host and device - an astounding 10x the capability of USB 2.0 (480Mbps).
The USB 3.0 extension cables features high quality Shielded Twisted Pair (STP) construction, helping to prevent electromagnetic interference and ensuring reliable data communication.
- StarTech.com 6 ft Black SuperSpeed USB 3.0 Extension Cable A to A M/F - 2m USB 3 Male to Female Ext Cable / Cord 6ft - 5Gbps (USB3SEXT6BK) - USB extension cable - USB Type A to USB Type A - 1.8 m
- Technology
- Shielded foiled twisted pair (SFTP)
- Length
- 1.8 m
- Connector
- 9 pin USB Type A - male
- Connector (Second End)
- 9 pin USB Type A - female
- USB / USB 2.0 / USB 3.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: 2SD4FCRU3, BNDDKT30CAHV, CFASTRWU3, FCREADMICRO3, MSDREADU3CA, S352BU33HR, ST3300G3UA, ST3300GU3B, ST7300U3M, SV1631DUSBUK, SV211DPUA, SV211DPUA4K, SV211HDUA4K, USB2001EXT2, USB2001EXT2NA, USB2002EXT2NA, USB2004EXT2, USB2004EXT2NA, USB31GEHD, USB31GEVG, USB3SAA3MBK, USB3SMDOCKHV, USBA2DPGB
- Technology
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Length
- 1.8 m
- Black
- Connector
- USB / USB 2.0 / USB 3.0, RoHS
- Designed For
- P/N: 2SD4FCRU3, BNDDKT30CAHV, CFASTRWU3, FCREADMICRO3, MSDREADU3CA, S352BU33HR, ST3300G3UA, ST3300GU3B, ST7300U3M, SV1631DUSBUK, SV211DPUA, SV211DPUA4K, SV211HDUA4K, SVUSB2N1_6, USB2001EXT2, USB2001EXT2NA, USB2002EXT2NA, USB2004EXT2, USB2004EXT2NA, USB31GEHD, USB31GEVG, USB3SAA3MBK, USB3SMDOCKHV, USBA2DPGB
