Connect USB 3.0 A devices to a USB hub or to your computer. StarTech.com's 6ft Black USB 3.0 cable (A-A) offers a durable, high quality connection that harnesses the full capability of the SuperSpeed USB 3.0 standard.
Designed for next-generation SuperSpeed USB device connections, this USB 3.0 A to A Male/Male cable provides connectivity between a PC and hub or other USB A devices, delivering a throughput of up to 5Gbps when used with a USB 3.0 host and device - an astounding 10x the capability of USB 2.0 (480Mbps).
The 6ft USB 3.0 A to A device cable features high quality Shielded Twisted Pair (STP) construction, helping to prevent electro-magnetic interference and ensuring reliable data communication.
- StarTech.com 6 ft / 2m Black SuperSpeed USB 3.0 Cable A to A - USB 3 A (m) to USB 3 A (m) (USB3SAA6BK) - USB cable - USB Type A to USB Type A - 1.8 m
- USB cable
- Technology
- Shielded twisted pair (STP)
- Molded, 5 Gbps data rate
- Length
- 1.8 m
- Connector
- 9 pin USB Type A - male
- Connector (Second End)
- USB 3.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: HB30C1A1CPD, HB30C3A1CFBW, HB30C3A1CST, HB30C3AGEPD, HB30C3APD, HB30C3APDW, HB30C4AB, HB30C4ABW, HB30C4AFPD, HB30C4AFS, HB30C5A2CSC, HB30C5A2CST, ST103008U2C, ST1030USBM, ST4300U3C1, ST4300U3C1B, ST53004U1C, ST7300U3M, ST7300USBME, ST93007U2C, SV231DPU34K, SV431DPU3A2, TB2USB3GE, USB3EXT6INBK
- USB cable
- Technology
- American Wire Gauge (AWG)
- 28
- Length
- 1.8 m
- Black
- Connector
- USB 3.0, RoHS
- Designed For
- P/N: ECUSB3S22, HB30C1A1CPD, HB30C3A1CFBW, HB30C3A1CST, HB30C3AGEPD, HB30C3APD, HB30C3APDW, HB30C4AB, HB30C4ABW, HB30C4AFPD, HB30C4AFS, HB30C5A2CSC, HB30C5A2CST, PCIUSB3S22, PCIUSB3S4, ST103008U2C, ST1030USBM, ST4300MINU3B, ST4300MINU3W, ST4300PBU3, ST4300U3C1, ST4300U3C1B, ST4300U3C3, ST53004U1C, ST7300U3M, ST7300USBME, ST93007U2C, SV231DPU34K, SV431DPU3A2, TB2USB3GE, USB32VGAEH, USB3EXT6INBK
StarTech.com 10 ft SuperSpeed USB 3.0 Cable A to B - M/M | In Stock | £7.60 |
StarTech.com 3 ft SuperSpeed USB 3.0 Cable A to B - M/M | In Stock | £2.92 |
StarTech.com 6 ft SuperSpeed USB 3.0 Cable A to B - M/M | In Stock | £4.88 |
StarTech.com 6 ft SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £6.21 |
