StarTech.com 6 ft Beige A to B USB 2.0 Cable - M/M
Quicklinx: 401CWS00 Mfr#: USBFAB_6
Length: 1.8m
30 in stock
£3.07 ex VAT
£3.68 inc VAT
Connect USB 2.0 peripherals to your computer. The USBFAB 6 6ft USB A-to-B cable features one USB 'A' male connector and one USB 'B' male connector, providing a high quality connection to USB 2.0 peripherals such as USB printers, scanners or external USB hard drives.
StarTech.com 6 ft Beige A to B USB 2.0 Cable - M/M - USB cable - 1.8 m
USB cable
Molded
Length
1.8 m
Connector
4 pin USB Type A - male
Connector (Second End)
4 pin USB Type B - male
Beige
P/N: 35BAYPANELBK
USB cable
Molded
Length
1.8 m
Beige
Connector
StarTech.com 3.5in Black Multi Port Panel for Front Drive Bay
401C StarTech.com 6 ft Beige A to B USB 2.0 Cable - M/M In Stock £3.07
401C StarTech.com 3 ft Beige A to B USB 2.0 Cable - M/M In Stock £2.84
401C StarTech.com 6 ft USB 2.0 Extension Cable A to A - M/F In Stock £3.52
401C StarTech.com 10 ft USB 2.0 Certified A to B Cable - M/M In Stock £3.90
401C StarTech.com USB A Gender Changer - F/F In Stock £3.81
401C StarTech.com 6 ft Beige A to A USB 2.0 Cable - M/M In Stock £3.42
401C StarTech.com 2 Port USB A Female Slot Plate Adapter In Stock £3.83
401C StarTech.com 6 ft USB 2.0 Certified A to B Cable - M/M In Stock £3.15
401C StarTech.com 6 ft Clear A to B USB 2.0 Cable - M/M In Stock £3.15
Length: 1.8m
Price Range Ex VAT: 0 - 50
