Provides a high speed, crystal clear connection between your DVI devices, even in tight spaces. The DVIDDMMTA6 6ft Dual Link DVI-D cable features a standard DVI-D dual link connector as well as a DVI-D dual link connector that is situated on an upward angle relative to the shaft of the cable, requiring only 40mm of space at the connection point.
The perfect solution for making digital video connections in tight spaces, the design of the upward angle cable connector helps prevent damage to the cable and ensures long-lasting performance by eliminating the need to bend or strain the cable to account for a lack of space.
The 6ft DVI-D digital monitor cable supports resolutions of up to 2560x1600 and transmission rates of up to 9.9 Gbits/sec, and is fully compliant with DVI DDWG standards.
- StarTech.com 6 ft 90 Degree Upward Angled Dual Link DVI-D Monitor Cable M/M - Male to Male 25 pin DVI-D Video Cable Black 6 Feet 2560x1600 (DVIDDMMTA6) - DVI cable - 1.8 m
- DVI cable - dual link
- 90° connector
- Length
- 1.8 m
- Connector
- DVI-D - male
- Connector (Second End)
- DVI-D - male
- RoHS
- Black
- Limited lifetime warranty
- Designed For
- P/N: MDP2DVID2, SV231DVIUAHR, SV431DVIUAHR
- DVI cable
- American Wire Gauge (AWG)
- 28
- TMDS Links
- Dual link
- Plated Connector
- Nickel
- 90° connector
- Length
- 1.8 m
- Black
- Connector
- 24+1 pin digital DVI - male
- RoHS
- Designed For
StarTech.com 6 ft DVI-D Dual Link Cable - M/M | In Stock | £8.14 |
StarTech.com 15 ft DVI-D Dual Link Cable - M/M | In Stock | £15.66 |
StarTech.com 10 ft DVI-D Dual Link Cable - M/M | In Stock | £12.86 |
StarTech.com 15 ft DVI-D Dual Link Monitor Extension Cable - M/F | In Stock | £14.78 |
StarTech.com 3 ft DVI-D Dual Link Cable - M/M | In Stock | £4.15 |
StarTech.com 40 ft DVI-D Dual Link Cable - M/M | In Stock | £52.88 |
StarTech.com 6 ft 90 Degree Upward Angled Dual Link DVI-D Monitor Cable - M/M | In Stock | £11.31 |
StarTech.com 20 ft DVI-D Dual Link Cable - M/M | In Stock | £20.29 |
