StarTech.com 6 ft 90 Degree Upward Angled Dual Link DVI-D Monitor Cable - M/M
Quicklinx: 6PDTWS00 Mfr#: DVIDDMMTA6
Type: DVI
Length: 1.8m
£11.31 ex VAT
£13.57 inc VAT
Provides a high speed, crystal clear connection between your DVI devices, even in tight spaces. The DVIDDMMTA6 6ft Dual Link DVI-D cable features a standard DVI-D dual link connector as well as a DVI-D dual link connector that is situated on an upward angle relative to the shaft of the cable, requiring only 40mm of space at the connection point.
The perfect solution for making digital video connections in tight spaces, the design of the upward angle cable connector helps prevent damage to the cable and ensures long-lasting performance by eliminating the need to bend or strain the cable to account for a lack of space.
The 6ft DVI-D digital monitor cable supports resolutions of up to 2560x1600 and transmission rates of up to 9.9 Gbits/sec, and is fully compliant with DVI DDWG standards.
StarTech.com 6 ft 90 Degree Upward Angled Dual Link DVI-D Monitor Cable M/M - Male to Male 25 pin DVI-D Video Cable Black 6 Feet 2560x1600 (DVIDDMMTA6) - DVI cable - 1.8 m
DVI cable - dual link
90° connector
Length
1.8 m
Connector
DVI-D - male
Connector (Second End)
DVI-D - male
RoHS
P/N: MDP2DVID2, SV231DVIUAHR, SV431DVIUAHR
DVI cable
American Wire Gauge (AWG)
28
TMDS Links
Dual link
Plated Connector
Nickel
90° connector
Length
1.8 m
Connector
24+1 pin digital DVI - male
RoHS
6PDT StarTech.com 6 ft DVI-D Dual Link Cable - M/M In Stock £8.14
6PDT StarTech.com 15 ft DVI-D Dual Link Cable - M/M In Stock £15.66
6PDT StarTech.com 10 ft DVI-D Dual Link Cable - M/M In Stock £12.86
6PDT StarTech.com 15 ft DVI-D Dual Link Monitor Extension Cable - M/F In Stock £14.78
6PDT StarTech.com 3 ft DVI-D Dual Link Cable - M/M In Stock £4.15
6PDT StarTech.com 40 ft DVI-D Dual Link Cable - M/M In Stock £52.88
6PDT StarTech.com 6 ft 90 Degree Upward Angled Dual Link DVI-D Monitor Cable - M/M In Stock £11.31
6PDT StarTech.com 20 ft DVI-D Dual Link Cable - M/M In Stock £20.29
Type: DVI
Length: 1.8m
Price Range Ex VAT: 0 - 50
