StarTech.com's professional line of 3-in-1 PS/2 KVM cables are specifically designed to work with your StarView or Server Remote Control KVM switch, integrating the necessary PS/2 peripheral connections as well as the VGA connection into a single cable - reducing tangles while maintaining excellent performance.
This 6ft 3-in-1 PS/2 KVM switch cable features an ultra-thin design and is constructed of only high quality materials. This cable is designed for durability and long-term reliability.
- StarTech.com 3-in-1 Ultra Thin PS/2 KVM Cable - Keyboard / video / mouse (KVM) cable - PS/2, HD-15 (VGA) (M) to HD-15 (VGA) (M) - 6 ft - SVECON6 - keyboard / video / mouse (KVM) cable - 1.8 m
- Molded
- Length
- 1.8 m
- Connectors
- 2 x 6 pin mini-DIN (PS/2 style) - male , 15 pin HD D-Sub (HD-15) - male
- Connectors (Second End)
- 15 pin HD D-Sub (HD-15) - male
- Limited lifetime warranty
- Designed For
- P/N: CAB1631HD, CAB831HD, CABCONS16, CABCONS1716I, CABCONS8, RACKCONS1908, RACKCONS1916, SV1631DUSB, SV1631DUSBGB, SV211K, SV411K, SV431DUSB, SV565UTP, SV831DUSB, SV831DUSBA, SV831DUSBGB, SV831HD, SV841HDIE, SV841HDIEGB
- Molded
- Length
- 1.8 m
- Connectors
- Designed For
StarTech.com 4 Port Black PS/2 KVM Switch Kit with Cables | In Stock | £56.48 |
StarTech.com 6 ft 3-in-1 Ultra Thin PS/2 KVM Cable | In Stock | £7.49 |
StarTech.com 16 Port 1U Rackmount USB PS/2 KVM Switch with OSD | In Stock | £490.32 |
StarTech.com 8 Port 1U Rackmount USB PS/2 KVM Switch with OSD | In Stock | £271.84 |
