The StarTech.com PC99 3-in-1 Extension Cable allows keyboard, monitor, and mouse cables to be extended without the mess and tangle of 3 separate traditional cables. The exclusive design takes 3 separate extension cables and fuses them into 1 neat tangle-free cable. Each connector end is color coded according to PC99 specifications for ease of identification when connecting the peripherals. The video component of the cable is constructed with high-quality mini-coaxial wire for crystal clear video quality at any resolution. Double shielding and a ferrite core on the video cable virtually eliminate any external signal interference. If a speaker extension is also required, check out the StarTech.com 4-in-1 extension cables.
- StarTech.com 6 ft 3-in-1 PS/2 KVM Extension Cable - keyboard / video / mouse (KVM) extension cable - 1.8 m
- Keyboard / video / mouse (KVM) extension cable
- Technology
- Shielded
- Length
- 1.8 m
- Connectors
- 15 pin HD D-Sub (HD-15) - male , 2 x 6 pin mini-DIN (PS/2 style) - male
- Connectors (Second End)
- 15 pin HD D-Sub (HD-15) - female , 2 x 6 pin mini-DIN (PS/2 style) - female
- Limited lifetime warranty
- Designed For
- P/N: SV211KT
- Technology
- Shielded
- Length
- 1.8 m
- Connectors
- Designed For
- StarTech.com StarView SV211KT
