StarTech.com 6 ft 180° Rotating High Speed HDMI Cable - HDMI - M/M
Quicklinx: 6PF0WS00 Mfr#: HDMIROTMM6
Connect HDMI-capable devices even in tight spaces. The HDMIROTMM6 High Speed HDMI Swivel Cable (6 ft) features two gold plated 180° flexible HDMI connectors, which provide a direct link between HDMI-enabled devices such as Blu-Ray players, HDTVs, DVD Players, stereo receivers and more.
The swiveling/pivoting HDMI connectors offer the ability to adjust your installations in tight/narrow spaces where standard connectors will not fit (e.g. wall-mounted flat panel televisions), without having to bend the cable at sharp angles.
StarTech.com HDMI cables fully support High-Definition resolutions up to and beyond 1080p, at up to 120Hz refresh rate, with life-like color, ensuring impressive HD video performance as well as multi-channel digital audio in a single cable.
Plus, the HDMI cables can support bandwidth up to 340 MHz (10.2 Gbps) and display resolutions of up to 1440p, ready for the demands of future high definition devices, such as increased resolutions and higher frame rates.
StarTech.com 6ft Swivel HDMI Cable, 4K High Speed Rotating HDMI Cord, 4K 30Hz UHD HDMI, 10.2 Gbps Bandwdith, HDMI 1.4 Video, HDCP 1.4, M/M HDMI Pivot Cable with 180° Swivel Connector - Rotating HDMI to HDMI Cable - HDMI cable - 1.8 m
Cable
HDMI cable
Double shielded
American Wire Gauge (AWG)
28
Length
1.8 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
180° rotating connector
P/N: HDMIEXTAA6IN
Cable Type
HDMI cable 180° rotating connector
Double shielded
28
Jacket Material
PVC
Shielding Material
Length
1.8 m
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
RoHS, NEC-CMG
Limited warranty - lifetime
P/N: HDMIEXTAA6IN
6PF0 StarTech.com Mini DVI to HDMI Video Adapter for Macbooks and iMacs- M/F In Stock £13.58
6PF0 StarTech.com HDMI Coupler / Gender Changer - F/F In Stock £8.38
6PF0 StarTech.com 6in High Speed HDMI 2.0 Port Saver Cable with 4K 60Hz - Grip In Stock £11.52
