Portable Security Cable Steel Cable 4-Digit Combination. Finding the right laptop lock to help protect against theft has never been easier. This universal laptop cable lock works with the most common security lock slots on laptops and other devices. The interchangeable lock heads are compatible with three different laptop lock slots: Kensington K-Slot, Kensington Nano, and Noble , Wedgelock .
To maximize security at the office or on the go, the laptop anti-theft lock uses a four-digit combination, with up to 10,000 passcode options.
Offers Greater Motion
While your laptop or other device is secured, you can move your device freely. The swivel hinge allows motion in two directions - the hinge rotates 360 degrees around the lock head, and pivots 90 degrees for easy locking and unlocking.
Resettable 4-Digit Combination Lock
Choose your own combination so you can remember it easily. Or, prevent others from knowing your passcode by changing it often.
Maximize Security
Ensure that your laptop, tablet, dock or other device is anchored safely to your workspace. This keyed cable lock features a durable zinc-alloy lock head, to provide dependable theft protection in a wide range of retail, commercial, and institutional environments.
The laptop lock can be used with StarTech.com deskmount anchors LTANCHOR and LTANCHORL to secure your equipment to any surface.
Versatile Use
Ideal for portable use or at the office, the computer cable lock features a 2 m (6.6 ft.) locking cable made of vinyl-coated steel (4.4 mm diameter). To secure your device in a variety of different work spaces, the flexible steel cable bends easily to loop around a stationary post or object.
The Choice of IT Pros Since 1985
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales.
LTULOCK4D is backed by a StarTech.com 2-year warranty and free lifetime technical support.
Offers greater motion
While your laptop or other device is secured, you can move your device freely. The swivel hinge allows motion in two directions - the hinge rotates 360 degrees around the lock head, and pivots 90 degrees for easy locking and unlocking. -
Resettable 4-digit combination lock
Choose your own combination so you can remember it easily. Or, prevent others from knowing your passcode by changing it often. -
Maximize security
Ensure that your laptop, tablet, dock or other device is anchored safely to your workspace. This keyed cable lock features a durable zinc-alloy lock head, to provide dependable theft protection in a wide range of retail, commercial, and institutional environments. -
Versatile use
- StarTech.com 6.5' (2m) 3-in-1 Universal Laptop Cable Lock, 4-Digit Combination Laptop/Desktop Security Cable Lock Compatible w/ K-Slot, Nano & Wedge Slot Computer, Anti-Theft Steel Cable - Universal Laptop Lock - security cable lock
- Product Type
- Security cable lock
- Package Content
- Hook-and-loop tie
- Product Material
- Vinyl-coated steel
- 4.96 cm 1.6 cm
- Length
- 2 m
- 155 g
- K-lock security slot, 4 digit code, anti-theft protection, 360° head rotation, cut-resistant, kensington security slot, noble wedge lock, 10000 user-settable combinations, Nano slot keyed lock
- 2-year warranty
- Product Type
- Product Material
- Package Content
- Hook-and-loop tie
- 4.96 cm
- 1.6 cm
- Length
- 2 m
- Thickness
- 4.4 mm
- 155 g
- Shipping Dimensions (WxDxH) / Weight
- 12.8 cm x 22 cm x 5 cm / 160 g
Security Cable Lock
- Lock Method
- Combination
- RoHS, REACH
- TAA Compliant
- Limited warranty: - 2 years
StarTech.com Nano Laptop Cable Lock | In Stock | £39.68 |
StarTech.com Laptop Cable Lock 6Ft | In Stock | £30.42 |
StarTech.com Universal Laptop Lock, 3-in-1 | In Stock | £32.01 |
StarTech.com Universal Laptop Lock, 3-in-1 | In Stock | £32.04 |
