StarTech.com 6' (2m) 3-in-1 Universal Laptop Cable Lock for K-Slot, Nano & Wedge Slot Desktop/Laptop
Quicklinx: FY2BWS00 Mfr#: LTULOCK4D
Device Type: Laptop
Type: Security
Device Screen Size: [N/A]
Colour: Silver/Black
15 In Stock
£22.74 ex VAT
£27.28 inc VAT
Portable Security Cable Steel Cable 4-Digit Combination. Finding the right laptop lock to help protect against theft has never been easier. This universal laptop cable lock works with the most common security lock slots on laptops and other devices. The interchangeable lock heads are compatible with three different laptop lock slots: Kensington K-Slot, Kensington Nano, and Noble , Wedgelock .
To maximize security at the office or on the go, the laptop anti-theft lock uses a four-digit combination, with up to 10,000 passcode options.
Offers Greater Motion
While your laptop or other device is secured, you can move your device freely. The swivel hinge allows motion in two directions - the hinge rotates 360 degrees around the lock head, and pivots 90 degrees for easy locking and unlocking.
Resettable 4-Digit Combination Lock
Choose your own combination so you can remember it easily. Or, prevent others from knowing your passcode by changing it often.
Maximize Security
Ensure that your laptop, tablet, dock or other device is anchored safely to your workspace. This keyed cable lock features a durable zinc-alloy lock head, to provide dependable theft protection in a wide range of retail, commercial, and institutional environments.
The laptop lock can be used with StarTech.com deskmount anchors LTANCHOR and LTANCHORL to secure your equipment to any surface.
Versatile Use
Ideal for portable use or at the office, the computer cable lock features a 2 m (6.6 ft.) locking cable made of vinyl-coated steel (4.4 mm diameter). To secure your device in a variety of different work spaces, the flexible steel cable bends easily to loop around a stationary post or object.
The Choice of IT Pros Since 1985
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales.
LTULOCK4D is backed by a StarTech.com 2-year warranty and free lifetime technical support.
  • Offers greater motion
  • Resettable 4-digit combination lock
  • Maximize security
  • Versatile use
StarTech.com 6.5' (2m) 3-in-1 Universal Laptop Cable Lock, 4-Digit Combination Laptop/Desktop Security Cable Lock Compatible w/ K-Slot, Nano & Wedge Slot Computer, Anti-Theft Steel Cable - Universal Laptop Lock - security cable lock - TAA Compliant
Security cable lock
Package Content
Hook-and-loop tie
Product Material
Vinyl-coated steel
4.96 cm 1.6 cm
Length
2 m
155 g
Nano slot keyed lock, noble wedge lock, kensington security slot, 4 digit code, 10000 user-settable combinations, cut-resistant, 360° head rotation, anti-theft protection, K-lock security slot
TAA Compliant
Security cable lock
Product Material
Vinyl-coated steel
Package Content
Hook-and-loop tie
4.96 cm
1.6 cm
Length
2 m
Thickness
4.4 mm
155 g
12.8 cm x 22 cm x 5 cm / 160 g
Security Cable Lock
Lock Method
Combination
RoHS, REACH
TAA Compliant
Limited warranty: - 2 years
FY2B StarTech.com Nano Laptop Cable Lock In Stock £31.28
FY2B StarTech.com Laptop Cable Lock 6Ft In Stock £24.79
FY2B StarTech.com Universal Laptop Lock, 3-in-1 In Stock £27.58
FY2B StarTech.com Universal Laptop Lock, 3-in-1 In Stock £30.15
FY2B StarTech.com 25-Pack Universal Laptop Lock In Stock £507.39
FY2B StarTech.com 25-Pack Universal Laptop Lock In Stock £587.62
FY2B StarTech.com 25-Pack Universal Laptop Lock In Stock £627.35
FY2B StarTech.com 3-in-1 Universal Laptop Lock In Stock £26.89
FY2B StarTech.com Computer/Peripheral Lock Kit In Stock £31.72
FY2B StarTech.com Laptop Nano Cable Lock, 5ft In Stock £16.28
FY2B StarTech.com Universal Laptop Cable Lock In Stock £24.52
Device Type: Laptop
Type: Security
