StarTech.com 5m USB 3.0 Active Extension Cable - M/F
Quicklinx: 80HSWS00 Mfr#: USB3AAEXT5M
Length: 5m
32 in stock
£57.89 ex VAT
£69.46 inc VAT
Extend the distance between a computer and a USB 3.0 device by an additional 5 meters. The USB3AAEXT5M, 5-meter Active USB 3.0 Extension Cable, offers one USB type-A (male) connector and one USB type-A (female) connector, and provides an active extension of USB 3.0 devices of up to 5-meters (16-feet). An all in one cable for overcoming distance restrictions as well as power source limitations; the active USB 3.0 extension cable incorporates bus powered active circuitry to ensure performance beyond the length limits of standard USB cables. Up to 4 of these cables can be daisy-chained together, allowing the connection to be extended a total of 20-meters. If necessary, the USB device can be powered from a wall outlet using the Universal AC power adapter provided with the cable. The USB3AAEXT5M extension cable (USB Extender) supports high speed USB 3.0 transfer rates of up to 5Gbps.
StarTech.com USB 3.0 Active Extension Cable - USB extension cable - 5 m
USB extension cable
Active cable (signal regeneration)
Length
5 m
Connector
9 pin USB Type A - male
Connector (Second End)
9 pin USB Type A - female
USB / USB 2.0 / USB 3.0
P/N: PEXUSB3S44V
USB extension cable
Plated Connector
Nickel
Length
5 m
Connector
USB / USB 2.0 / USB 3.0, FCC, RoHS
P/N: PEXUSB3S44V
80HS StarTech.com 10 ft SuperSpeed USB 3.0 Cable A to B - M/M In Stock £7.51
80HS StarTech.com 5m USB 3.0 Active Extension Cable - M/F In Stock £57.89
Length: 5m
Price Range Ex VAT: 50 - 100
