The USB2AAEXT5M 5m Active USB 2.0 Extension Cable offers one USB-A male connector and one USB-A female connector, and provides an active extension of USB 2.0 devices of up to 5-meters (15-feet).
An all-in-one cable for overcoming distance restrictions as well as power source limitations, the active USB 2.0 extension cable incorporates bus-powered active circuitry to ensure performance beyond the length limits of standard USB cables. Plus you can daisy chain 4 cables for a total USB extension of up to 20-meters.
If necessary, the cable can be powered from a wall outlet using the Universal AC power adapter that was provided with the cable - this will allow you to use USB bus-powered devices that may require extra power.
The USB2AAEXT5M repeater cable supports the full USB 2.0 bandwidth of 480 Mbps.
- StarTech.com 5m USB 2.0 Active Extension Cable M/F - 5 meter USB A Male to USB A Female USB 2.0 Repeater / Extender Cable - Black - 15ft (USB2AAEXT5M) - USB extension cable - USB to USB - 5 m
- Technology
- Shielded
- Active cable (signal regeneration), LED power indicator
- Length
- 5 m
- Connector
- 4 pin USB Type A - female
- Connector (Second End)
- 4 pin USB Type A - male
- USB / USB 2.0
- Black
- 2-year warranty
- Designed For
- P/N: LTUB1MBK, SVA5H2NEUA, UUSBOTG
- Technology
- Shielded
- Plated Connector
- Nickel
- Length
- 5 m
- Black
- Connector
- USB / USB 2.0, Plug and Play, FCC, RoHS
- 2-year warranty
- Designed For
StarTech.com 20m USB 2.0 Active Extension Cable - M/F | In Stock | £58.74 |
StarTech.com 35m USB 2.0 Active Extension Cable - M/F | In Stock | £97.66 |
StarTech.com 15m USB 2.0 Active Extension Cable - M/F | In Stock | £46.91 |
StarTech.com 10m USB 2.0 Active Extension Cable - M/F | In Stock | £41.46 |
