StarTech.com 5m Flat High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable
Quicklinx: 8196WS00 Mfr#: HDMM5MFL
Length: 5m
23 in stock
£13.55 ex VAT
£16.26 inc VAT
Create Ultra HD connections between your HDMI-enabled devices with minimal clutter; supports Ethernet Data Channel. The HDMM5MFL Flat High Speed HDMI Cable (5-meter) supports the advanced capabilities of the High Definition Multimedia Interface, including Ethernet data interconnectivity with compatible HDMI devices. The cable features a flat-shaft design that makes it the ideal solution for in-wall installations or installation under carpet or along baseboards.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
StarTech.com 5m Flat High Speed HDMI Cable with Ethernet Ultra HD 4kx2k - HDMI with Ethernet cable - 5 m
Cable
Shielded
American Wire Gauge (AWG)
28
Length
5 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
3D-Transmission
Cable Type
Shielded
28
Jacket Material
PVC
Shielding Material
Length
5 m
Plated Connector
Gold
3D-Transmission
Connector
19 pin HDMI Type A - male
RoHS
Limited warranty - lifetime
Length: 5m
Price Range Ex VAT: 0 - 50
