StarTech.com 5m 40G QSFP+ Active DAC Cable
Quicklinx: D9V4WS00 Mfr#: QSFPH40GACU5
Select:
Connect your Cisco 40GbE QSFP+ network devices with this cost-effective, active Twinax copper cable. This 40G QSFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
The active twinaxial cable is a fully hot-pluggable solution, supporting 40 Gigabit Ethernet applications connected through QSFP+ (Quad Small Form-Factor Pluggable) ports.
Designed for short-length, high-speed interconnects, this low-power, low-latency Twinax cable is a cost-effective alternative to fiber-optic cable assemblies, supporting short-distance applications such as point-to-point in-rack and across-rack network switch or server connections.
StarTech.com Cisco QSFP-H40G-ACU5M Compatible 5m 40G QSFP+ to QSFP+ Direct Attach Cable Twinax, 40GbE QSFP+ Copper DAC 40 Gbps Low Power Active Transceiver Module DAC Firepower ASR1000 - Lifetime Warranty (QSFPH40GACU5) - 40GBase direct attach cable - 5 m - black
40GBase direct attach cable - SFF-8436
Twinaxial
Active cable
Length
5 m
Connector
QSFP+ - latched
Connector (Second End)
QSFP+ - latched
Network Cable Type
Twinaxial
Jacket Material
PVC
American Wire Gauge (AWG)
24
Impedance
100 Ohm
Active cable
Length
5 m
316 g
Connector
QSFP+ - latched
QSFP+ - latched
FCC, RoHS, MSA
70 °C
D9V4 StarTech.com 7m 40G QSFP+ Active DAC Cable In Stock £284.20
