StarTech.com 5m 16.4ft 40G QSFP+ DAC Cable
Quicklinx: D9VBWS00 Mfr#: QSFPH40GCU5M
Length: 5m
Colour: Black
£112.90 ex VAT
£135.48 inc VAT
Connect your Cisco 40GbE QSFP+ network devices with this cost-effective, passive Twinax copper cable. This 40G QSFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This passive twinaxial cable is a fully hot-pluggable, direct-attach cable, supporting 40 Gigabit Ethernet applications connected through QSFP+ (Quad Small-Form Factor Pluggable) ports.
Designed for short-length, high-speed interconnects, this low-power, low-latency Twinax cable is a cost-effective alternative to fiber-optic cable assemblies, supporting short-distance applications such as point-to-point in-rack and across-rack network switch or server connections.
The QSFPH40GCU5M is a reliable replacement cable for the Cisco QSFP-H40G-CU5M.
StarTech.com Cisco QSFP-H40G-CU5M Compatible - QSFP+ Direct Attach Cable - 5 m (16.4 ft) - 40 GbE - direct attach cable - 5 m - black
Direct attach cable - SFF-8436
Twinaxial
Shielding Material
Copper
Passive cable, Hot-pluggable
Length
5 m
Connector
QSFP+
Connector (Second End)
QSFP+
Network Cable Type
Twinaxial
Shielding Material
Copper
Jacket Material
PVC
American Wire Gauge (AWG)
28
Impedance
100 Ohm
Length
5 m
1.8 cm
1.3 cm
316 g
Connector
QSFP+
QSFP+
FCC, RoHS, WEEE, RCM
70 °C
D9VB StarTech.com 0.5m 1.6ft 40G QSFP+ DAC Cable In Stock £57.96
D9VB StarTech.com 1m 3.3ft 40G QSFP+ DAC Cable In Stock £80.78
D9VB StarTech.com 3m 9.8ft 40G QSFP+ DAC Cable In Stock £87.33
D9VB StarTech.com 5m 16.4ft 40G QSFP+ DAC Cable In Stock £112.90
Length: 5m
Colour: Black
Price Range Ex VAT: 100 - 150
