Product
StarTech.com 5m (15ft) Active High Speed HDMI Cable – HDMI to HDMI Micro – M/M
Quicklinx: 9KN0WS00 Mfr#: HDADMM5MA
Length: 5m
Hurry, only 1 left in stock!
£20.17 ex VAT
£24.20 inc VAT
Connect an HDMI Micro-equipped smartphone or portable device up to 5m away from your HDMI-capable TV or display, with no signal loss. The HDADMM5MA Active HDMI to Micro HDMI cable features a built-in active signal booster that provides a connection distance of up to 15 feet (5m) between your HDMI Micro-equipped smartphone, tablet or other portable device and an HDMI-capable TV or display, with no signal loss.
This durable, lightweight cable features thinner HDMI wire construction - approximately half the thickness of a regular 5m cable, which allows for a more flexible installation with minimal clutter. Plus, the cable features built-in amplifier circuitry which actively boosts the HDMI signal with no external power required.
The active booster circuit and thin wire construction design of this cable makes it perfect for any mobile user, from people on the move with hectic schedules to anyone wanting to connect from the comfort of their couch. The cable is portable enough that it fits nicely inside your laptop bag, ensuring you always have the right cable to connect your mobile device to an HDMI display, and is slim enough that it provides a convenient connection to your TV without the hassle of bulky cables getting in your way - and all without the need of an external power source.
This cable features unidirectional architecture which requires that is installed in a specific direction. Please refer to the "Display" label on the HDMI connector which plugs into your display, in order to ensure that the device and the Micro HDMI source are connected properly.
StarTech.com 5m Active High Speed HDMI Cable - HDMI to HDMI Micro M/M - HDMI cable - 5 m
Cable
HDMI cable
Double shielded
American Wire Gauge (AWG)
36
Length
5 m
Connector
Micro HDMI - male
Connector (Second End)
HDMI - male
Active cable (signal regeneration)
2 years warranty
Cable Type
HDMI cable
Double shielded
36
Jacket Material
PVC
Shielding Material
Length
5 m
Plated Connector
Gold
Connector
19 pin micro HDMI Type D - male
19 pin HDMI Type A - male
RoHS
Length: 5m
Price Range Ex VAT: 0 - 50
