Product
StarTech.com 5in High Speed HDMI Adapter Cable - HDMI to HDMI Micro – F/M
Reduced Price - Whilst Stocks Last!
Quicklinx: 7RWMWS00 Mfr#: HDADFM5IN
Length: 1.2cm
Stock Status: Clearance
Hurry, only 2 left in stock!
£6.47 ex VAT
£7.76 inc VAT
Express delivery Order within the next 17 hours for delivery tomorrow
Connect your HDMI Micro Device or Smartphone to your HDMI-enabled TV or Monitor. The HDADFM5IN 5-inch HDMI to HDMI Micro Cable adapter enables you to use a standard HDMI male-to-male cable to connect your portable devices (BlackBerry PlayBook, Smartphones, etc.) to most video displays.
With a Standard HDMI female connector (type A) on one end and an HDMI Micro (type D) male connector on the other, you can easily make this conversion and connect to computer monitors, HDTV or HDMI projectors virtually everywhere you go.
The HDMI/HDMI Micro cable features high quality, gold-tipped connectors that ensure peak connectivity.
StarTech.com 5in High Speed HDMI Adapter Cable - HDMI to HDMI Micro - F/M - HDMI adapter - 1.2 cm
Cable
HDMI adapter
Shielded
American Wire Gauge (AWG)
34
Length
1.2 cm
Connector
HDMI - female
Connector (Second End)
Micro HDMI - male
P/N: HDMM30CM
Cable Type
HDMI adapter
Shielded
34
Jacket Material
PVC
Shielding Material
Length
1.2 cm
Plated Connector
Gold
Connector
19 pin HDMI Type A - female
19 pin micro HDMI Type D - male
RoHS
Limited warranty - lifetime
P/N: HDMM30CM
Length: 1.2cm
Price Range Ex VAT: 0 - 50
