StarTech.com 50x50x41mm Socket 7/370 CPU Cooler Fan with Heatsink and TX3 and LP4
Quicklinx: 4L36WS00 Mfr#: FANP1003LD
Type: Case Fan
25 in stock
£11.58 ex VAT
£13.89 inc VAT
This startech.com socket 7/730 CPU cooling fan optimizes heat dissipation and removal by combining a large heatsink and 5cm brushless ball bearing Fan. It is designed to provide quiet cooling to socket 370(PPGA) Celerons, socket 7 Pentiums, AMD K6, K6-2 and Cyrix chips. With a high efficiency Fan blade design capable of moving 9 CFM of air, the fan draws power using a 3-lead TX3 connector that plugs directly into the motherboard, allowing the system to monitor fan speed and operating status, and includes a 4-pin LP4 adapter to maximize compatibility with existing power supplies.
StarTech.com 50x41mm Socket 7/370 CPU Cooler Fan w/ Heatsink and TX3 and LP4 processor cooler
Processor cooler
Compatibility
Socket 370, Socket 7
Heatsink Material
Aluminium
Fan Diameter
50 mm
Fan Height
12.7 mm
Fan Bearing
Ball bearing
Rotation Speed
4500 rpm
Air Flow
9 cfm
Power Connector
3-pin plug, 4-pin fan connector
Processor cooler
Heatsink & Fan
Compatible With
Security Cable Lock
Processor Compatibility
AMD-K6-2 - up to 500 MHz , Celeron - up to 500 MHz
Heatsink Material
Aluminium
Heatsink Dimensions
50 mm x 50 mm x 22 mm
Fan Diameter
50 mm
Fan Height
12.7 mm
Fan Bearing
Ball bearing
Rotation Speed
4500 rpm
Air Flow
9 cfm
Power Connector
Sound Emission
28 dB
4L36 StarTech.com 12in Fan Adapter - TX3 to 2x LP4 Power Y Splitter Cable In Stock £2.76
Type: Case Fan
Price Range Ex VAT: 0 - 50
