StarTech.com 50x10mm Replacement Ball Bearing Computer Case Fan TX3/LP4 Connector
Quicklinx: 76S9WS00 Mfr#: FAN5X1TX3
Type: Case Fan
27 in stock
£5.81 ex VAT
£6.97 inc VAT
Overheating hardware can be a problem in most Server rooms. With StarTech.com's new LP4 Replacement Ball Bearing Fan, you can avoid problems to workstations. This fan exhausts hot air out of a PC, increasing dependability and extending component lifetime.
StarTech.com 50x10mm Replacement Ball Bearing Computer Case Fan TX3/LP4 Connector system fan kit
System fan kit
Fan Diameter
50 mm
Noise Level
25 dB
30 g
1-year warranty
System fan kit
30 g
Security Cable Lock
Fan Diameter
50 mm
Noise Level
25 dB
Limited warranty - 1 year
-10 °C
80 °C
76S9 StarTech.com LP4 to 2x LP4 Power Y Splitter Cable M/F In Stock £2.82
76S9 StarTech.com 60x20mm Replacement Ball Bearing Computer Case Fan with TX3 Connector In Stock £8.79
76S9 StarTech.com 60x10mm Replacement Ball Bearing Computer Case Fan with TX3 Connector In Stock £5.21
Type: Case Fan
Price Range Ex VAT: 0 - 50
