StarTech.com 50x10mm Replacement Ball Bearing Computer Case Fan TX3/LP4 Connector
Quicklinx: 76S9WS00 Mfr#: FAN5X1TX3
Type: Case Fan
14 In Stock
£5.87 ex VAT
£7.04 inc VAT
Overheating hardware can be a problem in most Server rooms. With StarTech.com's new LP4 Replacement Ball Bearing Fan, you can avoid problems to workstations. This fan exhausts hot air out of a PC, increasing dependability and extending component lifetime.
StarTech.com 50x10mm Replacement Ball Bearing Computer Case Fan TX3/LP4 Connector - 3 pin case Fan - TX3 Fan - 50mm Fan (FAN5X1TX3) - system fan kit
System fan kit
Fan Diameter
50 mm
Noise Level
25 dB
30 g
1-year warranty
System fan kit
30 g
Heatsink & Fan
Fan Diameter
50 mm
Noise Level
25 dB
Limited warranty: - 1 year
-10 °C
80 °C
76S9 StarTech.com LP4 to 2x LP4 Power Y Splitter Cable M/F In Stock £4.25
76S9 StarTech.com 60x10mm Replacement Ball Bearing Computer Case Fan with TX3 Connector In Stock £5.82
76S9 StarTech.com 6in TX3 Fan Power Splitter Cable In Stock £2.94
Type: Case Fan
