StarTech.com 50 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F
Quicklinx: 3ZK5WS00 Mfr#: MXT101HQ_50
Type: SVGA
Length: 15.2m
Hurry, only 2 left in stock!
£32.97 ex VAT
£39.56 inc VAT
This 50ft High Resolution VGA Extension Cable is designed to provide the highest video quality possible through VGA.
Ideally suited for high resolution VGA applications, this high quality male to female coaxial VGA extension cable helps to eliminates picture "ghosting" and fuzzy images inherent to non-coaxial cables, and provides superior EMI interference protection by using ferrite cores near the connector ends.
StarTech.com 50 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F (MXT101HQ_50) - VGA extension cable - 15.2 m
VGA extension cable
Molded
Length
15.2 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - female
P/N: DP2VGAMM6, DP2VGAMM6B, DS128, DSRXL, HD2VGAMM6, MXT101MM, ST122PROEU, ST122PROGB, ST124PROEU
VGA extension cable
Plated Connector
Nickel
Molded
Length
15.2 m
Connector
15 pin HD D-Sub (HD-15) - female
3ZK5 StarTech.com 50 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £32.97
3ZK5 StarTech.com 25 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £16.20
Type: SVGA
Length: 15.2m
Price Range Ex VAT: 0 - 50
