Product
StarTech.com 50 ft Cat5e Blue Molded RJ45 UTP Cat 5e Patch Cable
Quicklinx: 3ZZMWS00 Mfr#: M45PATCH50BL
Length: 15.2m
Colour: Blue
11 in stock
£11.71 ex VAT
£14.05 inc VAT
Make Fast Ethernet network connections using this high quality Cat5e Cable, with Power-over-Ethernet capability. The M45PAT50BL Cat5e Patch Cable (50 ft) meets or exceeds all Cat 5e specifications to ensure reliable Ethernet network connections, and features a durable blue PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat5e patch cable features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Cat5e Patch Cord delivers reliable performance.
  • 100% copper - a better value
    StarTech.com Cat5e cables are manufactured using high-quality copper conductors. While many cable manufacturers offer a "cheaper" cable, based on a copper-coated aluminum core, StarTech.com makes no compromises on quality to ensure you receive top value and performance for your network cable investment.
  • 24 AWG wire
    This Cat 5e cable is constructed with 24 gauge copper wire, to support a broad range of Ethernet applications such as Power over Ethernet (PoE). Because StarTech.com uses a high quality copper wire, these cables easily sustain the power required for Power over Ethernet applications, whereas the inferior quality offered by copper-coated aluminum cables may be subject to insufficient power delivery, heat buildup, equipment damage and potentially, fire.
  • 50-micron gold connectors
    This RJ45 patch cable offers high quality connectors comprised of 50-micron gold, to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
StarTech.com 50 ft Blue Cat5e / Cat 5 Molded Patch Cable 50ft - patch cable - 15.2 m - blue
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded
Length
15.2 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
P/N: ST121UTPDVEU, ST124UTPEAGB, ST128UTPEAGB, STUTPEALRGB, ST121UTP23GB, ST121UTPDVGB, ST128UTPEA, ST121HDMR50, ST121HDMIT, STUTPEALR, ST124UTPEA, PEX100S, ST121UTPDVI, NETRS2321E, ST121UT232GB, ST121UTP232, PS2UTPEXT, STUTPRXL, ST128UTPE, ST124UTPE, NETRS232_4GB, USB6N1DOCKGB, RS232EXTC5
Network Cable Type
Wiring Scheme
T568B
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Molded
Length
15.2 m
Blue
Connector
RJ-45 - male
RJ-45 - male
UL
StarTech.com 1 Port Cat5 USB Extender, 1 Port PCI Express 10/100 Ethernet Network Interface Adapter Card, 1 Port RS-232/422/485 Serial over IP Ethernet Device Server, 4 Port VGA Video Extender over Cat 5 (UTPE Series), 6-in-1 Black USB 2.0 Laptop Docking Station / Port Replicator, 8 Port VGA and Audio over Cat 5 Video Extender, 8 Port VGA Video Extender over Cat 5 (UTPE Series), DVI Video Extender over Cat5, HDMI over Cat 5 Video Extender - Receiver, HDMI Video Extender over Cat 5, PS/2 Keyboard and Mouse Extender over Cat 5, RS-232 Serial Ethernet IP Adapter (Device Server, Console Server), Serial DB9 RS232 Extender over Cat 5 - Up to 3300 ft (1000 meters), VGA Video Extender over Cat 5 Remote Receiver with Audio, VGA Video Extender over Cat 5 with RS232 , StarTech.com Converge A/V 4 Port VGA and Audio over Cat 5 Video Extender, HDMI Over CAT5 / UTP Receiver , StarTech.com USBthere 4 Port 100m USB Extender
Length: 15.2m
Colour: Blue
Price Range Ex VAT: 0 - 50
