Expand your network connectivity with this rugged unmanaged 10/100Mbps switch. This compact 5-port industrial Ethernet switch is engineered to deliver fast, reliable network connectivity and durability in the most demanding industrial environments. It provides top performance in a wider range of operating temperatures than conventional network switches, making it ideal for factories and warehouses.
Designed with a rugged IP30-rated housing, the network switch delivers maximum performance even in harsh industrial conditions. Its wide-range terminal block input gives you the flexibility to power the switch as required, based on your own power input source, while its wide operating temperature range keeps your network running smoothly.
This industrial Ethernet switch is easy to install, with an attached metal bracket for DIN rail mounting on equipment racks and cabinets.
Now you can eliminate the hassle of troubleshooting mismatched speed and duplex settings. This switch gives you full/half-duplex auto-negotiation and auto MDI/MDIX operation, enabling you to connect your network devices quickly and easily with little to no configuration required.
With lower overall power consumption, the Ethernet switch enhances your energy efficiency, in turn helping you reduce monthly costs.
Conquer the tough demands of industrial environments
Designed with a rugged IP30-rated housing, the network switch delivers maximum performance even in harsh industrial conditions. Its wide-range terminal block input gives you the flexibility to power the switch as required, based on your own power input source, while its wide operating temperature range keeps your network running smoothly. -
Get up and running in no time
This industrial Ethernet switch is easy to install, with an attached metal bracket for DIN rail mounting on equipment racks and cabinets. Now you can eliminate the hassle of troubleshooting mismatched speed and duplex settings. This switch gives you full/half-duplex auto-negotiation and auto MDI/MDIX operation, enabling you to connect your network devices quickly and easily with little to no configuration required. -
Reduce your energy costs with energy-efficient Ethernet
- StarTech.com 5-Port Ethernet Switch - 10/100Mbps Industrial Networking Solution - IP30-rated Energy Efficient Internet Switch (IES5102) - switch - 5 ports - unmanaged
- Switch - 5 ports - unmanaged
- Subtype
- Fast Ethernet
- Ports
- 5 x 10/100
- Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, half duplex mode, full duplex mode, Quality of Service (QoS), Jumbo Frames support, plastic housing, Energy Efficient Ethernet, 56KB packet buffer
- IEEE 802.3, IEEE 802.3u, IEEE 802.3x, IEEE 802.3az
- 11 cm x 7 cm x 2.5 cm
- 148 g
- Black
- 2-year warranty
- Designed For
- P/N: NETRS2322P
- Enclosure Type
- DIN rail mountable
- Subtype
- Fast Ethernet
- Ports
- 5 x 10/100
- Status Indicators
- Power, active, link/activity
- 4 x 100Base-TX RJ-45 , 1 x 100Base-TX RJ-45 uplink
- Power Device
- External power adapter
- 2.12 Watt
- Black
- Included Accessories
- 3-pin power terminal block
- MTBF
- 1,179,133 hours
- EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, EN 61000-4-5, FCC, EN 61000-6-2, RoHS, EN 61000-4-8, EN 61000-6-4, IEC 60068-2-27, IEC 60068-2-6, IP30
- 11 cm
- 7 cm
- 2.5 cm
- 148 g
- Limited warranty - 2 years
- -10 °C
- 60 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -25 °C
- Max Storage Temperature
- 85 °C
- Humidity Range Storage
- Designed For
- P/N: NETRS2322P
