Add a USB Type-C (USB 3.1 Gen 2 - 10Gbps) port to your computer, plus two USB Type-A ports, and two motherboard-style headers (5Gbps). This 5-port USB 3.1 combo card makes it easy to add to the performance and connectivity of your computer. It's one of the only USB 3.1 cards to offer a USB Type-C port (10Gbps), traditional USB Type-A ports (5Gbps), and a motherboard header.
By offering a range of USB port types, you can easily connect a variety of modern and legacy USB devices, both inside and outside your computer.
Because the card offers a 10Gbps USB-C port (USB 3.1 Gen 2), you can save time and avoid the performance bottlenecks that are often associated with other connectivity technologies.
This versatile PCI Express combo card leverages the performance potential of USB 3.1 to help you work faster. The USB-C port offers a data throughput of up to 10Gbps, so you can spend less time waiting for file transfers to complete or for access to your external peripherals.
Plus, you can rest assured that you're set for the future, as USB-C devices become more popular and more standardized.
Now you can easily add a variety of types and speeds (generations) of USB ports to your desktop or server, using a single adapter card. The card features: One external USB-C port (USB 3.1 Gen 2 - 10Gbps); Two external USB-A ports (USB 3.1 Gen 1 - 5Gbps); Two internal USB-A motherboard header ports (USB 3.1 Gen 1 - 5Gbps).
With a range of port types, the card lets you bridge the gap between older and newer devices that use different connectors. You can simultaneously connect and access USB Type-A and USB Type-C devices, while using only a single PCI Express expansion slot.
By adding three types of USB ports in one combo card, you can free up space in your PC case, and eliminate the nuisance of having different cards for different USB devices.
With two internal motherboard-style headers, this dynamic USB 3.1 card is perfect for upgrading or building your own computer. If your existing headers are occupied, or if you don't have any motherboard headers, you can connect front panel hubs or card readers using this versatile alternative to costly motherboard or computer upgrades.
Connecting your older peripherals isn't a problem. This 5-port USB 3.1 card is backward compatible with legacy USB 3.0 and 2.0 devices, so you can eliminate the added expense and aggravation of purchasing new devices. (USB 3.0 is also known USB 3.1 Gen 1).
The card does not support DP alt mode or USB Power Delivery.
- StarTech.com USB 3.1 PCIE Card - 5 Port - 1x USB-C - 2x USB-A - 1x 2 Port IDC - Internal USB Header Expansion - USB C PCIe Card (PEXUSB312EIC) - USB adapter - PCIe - USB 3.1 Gen 2 x 1 + USB 3.0 x 2 + USB 3.0 (internal) x 2
- USB adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express
- PCI Specification Revision
- PCIe 3.0
- Ports
- 1.8 cm x 7.93 cm x 12 cm
- 100 g
- Data Link Protocol
- USB 2.0, USB 3.0, USB 3.1
- Data Transfer Rate
- 10 Gbps
- Processor
- ASM1142 ASM1142
- USB 2.0, USB 3.0, xHCI, USB 3.1
- System Requirements
- Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Apple OS X 10.8 Mountain Lion, Apple OS X 10.9 Mavericks, Apple OS X 10.10 Yosemite, Microsoft Windows 7 / 8 / 10, Linux 3.5
- 2-year warranty
- Designed For
- P/N: CFASTRWU3C, FCREADU3C, HB30C3A1GEA, HB30C3AGEPD, HB31C2A1CGB, HB31C2A1CGS, HB31C2A2CB, HB31C3A1CB, HB31C3A1CPD3, HB31C3A1CS, HB31C3ASDMB, HB31C4AS, S251BRU31C3, S352BU313R, SDMSDRWU3AC, TB31PCIEX16, USB3C2ESAT3
- USB adapter
- Form Factor
- Plug-in card
- PCI Express
- PCIe 3.0
- Ports
- Connectivity Technology
- Wired
- USB 2.0, SuperSpeed USB 3.0, USB 3.1
- 10 Gbps
- USB Attached SCSI Protocol (UASP)
Processor / Memory
- Processor
- ASM1142 ASM1142
- 1 x USB-C - 19 pin USB 3.1 header (external) , 2 x USB 3.0 - 9 pin USB Type A (external) , 2 x USB 3.0 - 9 pin USB Type A (internal)
- Included Accessories
- Low-profile bracket
- FCC, RoHS
- OS Required
- 1.8 cm
- 7.93 cm
- 12 cm
- 100 g
- Limited warranty - 2 years
- 0 °C
- 70 °C
- 5 - 95% (non-condensing)
- Designed For
StarTech.com 1 Port Flush Mount ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support | In Stock | £17.59 |
StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 4 Dedicated 5Gbps Channels | In Stock | £73.15 |
StarTech.com 4 Port PCIe USB 3.0 Card | In Stock | £25.36 |
StarTech.com 2Port USB 3.1 10Gbps Card PCIe | In Stock | £33.61 |
