StarTech.com 5 Port USB 3.1 (10Gbps) Card
Quicklinx: CC3SWS00 Mfr#: PEXUSB312EIC
Wired / Wireless: Wired
Protocol: SuperSpeed USB 3.0, USB 2.0, USB 3.1
Compatibility: Mac, PC, Unix
Type: USB adapter
Hurry, only 1 left in stock!
£41.85 ex VAT
£50.22 inc VAT
Add a USB Type-C (USB 3.1 Gen 2 - 10Gbps) port to your computer, plus two USB Type-A ports, and two motherboard-style headers (5Gbps). This 5-port USB 3.1 combo card makes it easy to add to the performance and connectivity of your computer. It's one of the only USB 3.1 cards to offer a USB Type-C port (10Gbps), traditional USB Type-A ports (5Gbps), and a motherboard header.
By offering a range of USB port types, you can easily connect a variety of modern and legacy USB devices, both inside and outside your computer.
Because the card offers a 10Gbps USB-C port (USB 3.1 Gen 2), you can save time and avoid the performance bottlenecks that are often associated with other connectivity technologies.
This versatile PCI Express combo card leverages the performance potential of USB 3.1 to help you work faster. The USB-C port offers a data throughput of up to 10Gbps, so you can spend less time waiting for file transfers to complete or for access to your external peripherals.
Plus, you can rest assured that you're set for the future, as USB-C devices become more popular and more standardized.
Now you can easily add a variety of types and speeds (generations) of USB ports to your desktop or server, using a single adapter card. The card features: One external USB-C port (USB 3.1 Gen 2 - 10Gbps); Two external USB-A ports (USB 3.1 Gen 1 - 5Gbps); Two internal USB-A motherboard header ports (USB 3.1 Gen 1 - 5Gbps).
With a range of port types, the card lets you bridge the gap between older and newer devices that use different connectors. You can simultaneously connect and access USB Type-A and USB Type-C devices, while using only a single PCI Express expansion slot.
By adding three types of USB ports in one combo card, you can free up space in your PC case, and eliminate the nuisance of having different cards for different USB devices.
With two internal motherboard-style headers, this dynamic USB 3.1 card is perfect for upgrading or building your own computer. If your existing headers are occupied, or if you don't have any motherboard headers, you can connect front panel hubs or card readers using this versatile alternative to costly motherboard or computer upgrades.
Connecting your older peripherals isn't a problem. This 5-port USB 3.1 card is backward compatible with legacy USB 3.0 and 2.0 devices, so you can eliminate the added expense and aggravation of purchasing new devices. (USB 3.0 is also known USB 3.1 Gen 1).
The card does not support DP alt mode or USB Power Delivery.
StarTech.com USB 3.1 PCIE Card - 5 Port - 1x USB-C - 2x USB-A - 1x 2 Port IDC - Internal USB Header Expansion - USB C PCIe Card (PEXUSB312EIC) - USB adapter
USB adapter
Plug-in card
Interface (Bus) Type
PCI Express
PCI Specification Revision
PCIe 3.0
Ports
USB 3.1 Gen 2 x 1 + USB 3.0 x 2 + USB 3.0 (internal) x 2
1.8 cm x 7.93 cm x 12 cm
100 g
USB 2.0, USB 3.0, USB 3.1
Data Transfer Rate
10 Gbps
ASM1142
USB 2.0, USB 3.0, xHCI, USB 3.1
Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Apple OS X 10.8 Mountain Lion, Apple OS X 10.9 Mavericks, Apple OS X 10.10 Yosemite, Microsoft Windows 7 / 8 / 10, Linux 3.5
P/N: CFASTRWU3C, FCREADU3C, HB30C3A1GEA, HB30C3AGEPD, HB31C2A1CGB, HB31C2A1CGS, HB31C2A2CB, HB31C3A1CB, HB31C3A1CPD3, HB31C3A1CS, HB31C3ASDMB, HB31C4AS, S251BRU31C3, S352BU313R, SDMSDRWU3AC, TB31PCIEX16, USB3C2ESAT3
USB adapter
Plug-in card
PCI Express
PCIe 3.0
Ports
Wired
USB 2.0, SuperSpeed USB 3.0, USB 3.1
Data Transfer Rate
10 Gbps
USB Attached SCSI Protocol (UASP)
Processor / Memory
ASM1142
1 x USB-C - 19 pin USB 3.1 header (external) , 2 x USB 3.0 - 9 pin USB Type A (external) , 2 x USB 3.0 - 9 pin USB Type A (internal)
Low-profile bracket
FCC, RoHS
1.8 cm
7.93 cm
12 cm
100 g
70 °C
5 - 95% (non-condensing)
CC3S StarTech.com 1 Port Flush Mount ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support In Stock £17.59
CC3S StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 4 Dedicated 5Gbps Channels In Stock £72.27
CC3S StarTech.com 4 Port PCIe USB 3.0 Card In Stock £25.36
CC3S StarTech.com 2Port USB 3.1 10Gbps Card PCIe In Stock £33.61
Protocol: USB 2.0
Protocol: USB 3.1
Compatibility: Mac
Compatibility: PC
Compatibility: Unix
Type: USB adapter
Price Range Ex VAT: 0 - 50
