Add 5 USB 2.0 ports to any desktop computer with a PCI slot. This PCI-based High Speed USB 2.0 Adapter Card adds five USB 2.0 'A' Female ports (1 internal, 4 external) to your PCI-capable PC.
Supported by popular operating systems including Windows 98SE/ME/2000/XP/Vista, the PCI USB 2.0 card is a versatile solution that lets you add USB 2.0 connections without having to upgrade the system motherboard.
A convenient and time-saving solution, the PCI USB card is WHQL certified to simplify driver installation in Windows XP operating environments, and supports USB device hot-swapping - allowing you to connect/disconnect USB peripherals without having to power down the computer.
StarTech.com 5 Port PCI High Speed USB 2.0 Adapter Card - USB adapter - PCI - 5 ports
USB adapter
Plug-in card
Interface (Bus) Type
PCI
Ports Qty
5 ports
USB 2.0
Data Transfer Rate
480 Mbps
Microsoft Windows 98 Second Edition / Windows ME, Microsoft Windows 2000 / XP
P/N: ICUSB1284, ICUSB128410, ICUSB1284D25, ICUSB2321FIS, ICUSB2321X, ICUSB2322F, ICUSB2322I, ICUSB2322X, ICUSB2324X, ICUSB2328I, ICUSB232FTN, ICUSBAUDIO, ICUSBAUDIO7D, ICUSBAUDIOB, ST7202USBGB, SVKMS2
USB adapter - 5 ports
Plug-in card
PCI
Wired
USB 2.0
Data Transfer Rate
480 Mbps
4 x USB 2.0 - 4 pin USB Type A (external) , 1 x USB 2.0 - 4 pin USB Type A (internal)
Compatible Slots
1 x PCI
Plug and Play
Software Included
Drivers & Utilities
Limited warranty - lifetime
