Add 4 external USB ports and 1 internal USB port to your computer through a PCI Express slot. This 5 Port PCI Express USB 2.0 adapter card lets you connect up to five USB 2.0 peripherals (4 external and 1 shared internal) to your computer, with support for high speed USB data transfer rates of up to 480 Mbps.
Plus, the PCI Express USB card is backward compatible with USB 1.1, so you can continue using your older USB peripherals.
Featuring easy plug and play installation, this adapter card provides convenient, hassle-free connections without having to reboot the host computer.
- StarTech.com 5 Port PCI Express USB 2.0 Adapter Card - USB adapter - PCIe - 5 ports
- USB adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express x1
- Ports Qty
- 5 ports
- Data Link Protocol
- USB, USB 2.0
- Data Transfer Rate
- 480 Mbps
- System Requirements
- Microsoft Windows 2000, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
- Limited lifetime warranty
- Designed For
- P/N: ICUSB2322I, ICUSB2328I
- USB adapter - 5 ports
- Form Factor
- Plug-in card
- PCI Express x1
- Connectivity Technology
- Wired
- USB, USB 2.0
- 480 Mbps
- 4 x USB 2.0 - 4 pin USB Type A (external) , 1 x USB 2.0 - 4 pin USB Type A (internal)
- Compatible Slots
- 1 x PCI Express x1
- UL, FCC
- OS Required
- Limited warranty - lifetime
- Designed For
