Connect five Ethernet devices to your network, including two Power over Ethernet (802.3af) devices, even in locations without a power source. This PoE-powered 5-port Gigabit Ethernet switch expands your network connectivity in remote locations where a power source is not available. For added versatility, you can power and network your Gigabit PoE-powered devices (PD) using two 802.3af PSE (Power Sourcing Equipment) ports. The durable metal housing and redundant power input make the switch ideal for harsh environments.
The Gigabit network switch is powered through your existing PoE network infrastructure, so you can deploy it without an external power adapter. Plus, you have more flexibility to install the switch exactly where you need it, with no added aggravation or costs. Plus, the switch supports the most common types of PoE power input, including 802.3af/at networks.
This Power over Ethernet switch features two 802.3af ports, so you can deliver power and data to your PoE PDs without the costs of additional PoE injectors or switches. The PoE switch provides 15W of total power output across both ports. Now you can adequately power and connect your PoE devices such as IP phones and cameras in situations where a typical AC-powered network device can't be used.
For applications where a power source is available, you can connect the optional power adapter and deliver up to 15W to each PSE port.
For added reassurance and convenience, the 5-Port Gigabit Ethernet Switch offers redundant power input using the included power adapter. With both PoE and AC power input, the versatile switch can remain operational during power dips, failures, or outages, making it perfect for factories, warehouses, and other industrial environments.
- StarTech.com 5 Port Gigabit Ethernet Switch - PoE-Powered - 2 PSE/PoE Ports - switch - 5 ports - unmanaged
- Switch - 5 ports - unmanaged
- Subtype
- Gigabit Ethernet
- Ports
- 5 x 10/100/1000
- Power Over Ethernet (PoE)
- PoE+
- Performance
- Forwarding performance (full duplex): 2 Gbps
- MAC Address Table Size
- 4000 entries
- Jumbo Frame Support
- 9KB
- Flow control, auto-negotiation, store and forward, half duplex mode, full duplex mode, 128KB packet buffer
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
- Power
- AC 120/230 V
- 8.4 cm x 15 cm x 2.6 cm
- 355 g
- Black
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- Gigabit Ethernet
- Ports
- 5 x 10/100/1000
- PoE+
- Performance
- 4000 entries
- 9KB
- Status Indicators
- Power, PoE, link/activity, uplink
- 5 x 1000Base-T RJ-45
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- 60 Watt
- Black
- EN 61000-4-2, EN 61000-4-5, FCC, RoHS
- 8.4 cm
- 15 cm
- 2.6 cm
- 355 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
StarTech.com 100 ft Yellow Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £36.45 |
StarTech.com 75 ft Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £29.25 |
StarTech.com 1 Port RS232 Serial to IP Ethernet Converter / Device Server - Aluminum | In Stock | £123.57 |
StarTech.com 4 Port Gigabit PoE+ Injector | In Stock | £120.53 |
StarTech.com Gigabit PoE+ Extender - 100m | In Stock | £95.79 |
