Product
StarTech.com 5 Port Gigabit PoE Switch
Quicklinx: BKC0WS00 Mfr#: IES51GPOEPD
Type: Gigabit Ethernet
Ports: 5
Managed: No
POE: PoE+
£104.92 ex VAT
£125.90 inc VAT
Connect five Ethernet devices to your network, including two Power over Ethernet (802.3af) devices, even in locations without a power source. This PoE-powered 5-port Gigabit Ethernet switch expands your network connectivity in remote locations where a power source is not available. For added versatility, you can power and network your Gigabit PoE-powered devices (PD) using two 802.3af PSE (Power Sourcing Equipment) ports. The durable metal housing and redundant power input make the switch ideal for harsh environments.
The Gigabit network switch is powered through your existing PoE network infrastructure, so you can deploy it without an external power adapter. Plus, you have more flexibility to install the switch exactly where you need it, with no added aggravation or costs. Plus, the switch supports the most common types of PoE power input, including 802.3af/at networks.
This Power over Ethernet switch features two 802.3af ports, so you can deliver power and data to your PoE PDs without the costs of additional PoE injectors or switches. The PoE switch provides 15W of total power output across both ports. Now you can adequately power and connect your PoE devices such as IP phones and cameras in situations where a typical AC-powered network device can't be used.
For applications where a power source is available, you can connect the optional power adapter and deliver up to 15W to each PSE port.
For added reassurance and convenience, the 5-Port Gigabit Ethernet Switch offers redundant power input using the included power adapter. With both PoE and AC power input, the versatile switch can remain operational during power dips, failures, or outages, making it perfect for factories, warehouses, and other industrial environments.
StarTech.com 5 Port Gigabit Ethernet Switch - PoE-Powered - 2 PSE/PoE Ports - switch - 5 ports - unmanaged
Switch - 5 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
Power Over Ethernet (PoE)
PoE+
Performance
Forwarding performance (full duplex): 2 Gbps
MAC Address Table Size
4000 entries
Jumbo Frame Support
9KB
Flow control, auto-negotiation, store and forward, half duplex mode, full duplex mode, 128KB packet buffer
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
AC 120/230 V
8.4 cm x 15 cm x 2.6 cm
355 g
2 years warranty
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
PoE+
Performance
4000 entries
Jumbo Frame Support
9KB
Status Indicators
Power, PoE, link/activity, uplink
5 x 1000Base-T RJ-45
External power adapter
AC 120/230 V
60 Watt
EN 61000-4-2, EN 61000-4-5, FCC, RoHS
8.4 cm
15 cm
2.6 cm
355 g
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
BKC0 StarTech.com 25ft Purple Cat6 Patch Cable In Stock £7.22
BKC0 StarTech.com 100 ft Yellow Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £24.49
BKC0 StarTech.com 75 ft Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £20.64
BKC0 StarTech.com 1 Port RS232 Serial to IP Ethernet Converter / Device Server - Aluminum In Stock £100.94
BKC0 StarTech.com 4 Port Gigabit PoE+ Injector In Stock £107.58
BKC0 StarTech.com Gigabit PoE+ Extender - 100m In Stock £75.49
Ports: 5
Managed: No
POE: PoE+
Price Range Ex VAT: 100 - 150
